02-03-2014, 01:35 PM | #1 |
Drives: 2018 Camaro 2SS, Garnet Red Join Date: Jan 2014
PVC replacement for catch can
Anyone know where you can pick up a PVC hose for a catch can installation so you do not have to cut into your OEM. Is this something can pick up from autozone (would need part number) or would the dealership have to order it from GM?
02-03-2014, 03:03 PM | #2 |
Drives: 2013 VR 2LT/RS Join Date: May 2013
Hey, I had done the same thing when I installed catch can on mine. Just get in touch with Maureen over at Rodgers Chevrolet and I am sure she will be able to help you out.
2013 Victory Red 2LT/RS "I don't break rules. I just bend'em - a lot!" -Sideswipe |
02-03-2014, 03:05 PM | #3 |
Emerald Coast Camaros
Drives: 2017 2SS A8 50th Anniversary Join Date: Sep 2011
I don't know the exact type/# but I would venture to guess any auto parts store should sell it by the foot or at least packaged in short lengths. NAPA, CarQuest, etc. would be good places to try, probably also your AutoZone, Advance/Discount Auto, O'Reillys, etc. My guess is ordering it from GM would be overkill.
Current: 2017 2SS 50th Anniversary (#350)- 12.22 @ 115mph
- MX0 8-speed automatic, CF5 power sunroof Former: 2012 1LT/RS A6 - 14.11 @ 99.75mph Order: TMFF65 1100 - 5/19/16 | 2000 - 5/26/16 | 3000 - 6/1/16 3100 - 6/6/16 (TPW 6/20) | 3300 - 6/9/16 3400 - 6/10/16 | 4200 - 6/23/16 | 4300 - 6/28/16 5000 - 6/30/16 | 6000 - 7/1/16 Club F1FTY |
02-04-2014, 03:01 PM | #4 |
Drives: '12 2LT Convertible Join Date: Mar 2012
You need to buy it from a dealer so it has the correct ends to attach to the valve cover and manifold.
I bought one and cut off the ends. That way I have the original to go back to stock if I need to. Contact Maureen @ Rodgers.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
02-04-2014, 06:29 PM | #5 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Part number is 12638437 for the tube and 12616909 is the oring, for the LFX. The LLT tube and connections came with the orings.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
02-05-2014, 10:46 PM | #6 |
Is this for Gmpartsdirect or what?
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
02-08-2014, 03:46 PM | #7 |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Those are the GM parts numbers, so you can search/order them from whoever stocks them (dealers, aftermarket, etc.) by those numbers.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
02-09-2014, 09:37 AM | #8 |
Guest
Drives: bbbbbb Join Date: Dec 2012
I am going to look into getting the replacement so I can pull the catch can off in the winter months. Getting tired of trying to unscrew a cold can of frozen water once a week to dump. I don't drive it that hard this time of the year so I would like to pull it out for the winter months. After 5 to 7 days of 13 mile, 26 mile round trip the can is just about full of water and a few drop of oil. I could just as well be running it back into the engine this time of the year.
Dean. |
02-09-2014, 10:08 AM | #9 | |
Here's what came out (mind you, this is in a 59 oz juice bottle): There was a LOT of liquid in there. Mostly water, I'm sure, but clearly some other stuff, too, to give it that tan color. It's way lighter in color (which I think means more water) than when I emptied it in October: And that was in a 16 oz water bottle. Definitely need to empty it more often. OK...sorry about the
02-09-2014, 06:20 PM | #10 |
Anyone know of any hose that can replace the rubber hoses I was supplied with the catchcan, the rubber makes some pretty loud hissing noise.
02-09-2014, 08:48 PM | #11 |
Go Gators!
Drives: Camaro Jeep Abarth 944 325i Join Date: Jan 2013
If you can find out the inside diameter you can just get some high grade rubber hose from Lowes, Home Depot, Ace, or even your favorite auto parts store. Think they sell them in 6 inch or 12 inch increments...
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts Engine Mods: All bolt ons (haha) Brake Mods: Brembo SS caliper swap front and rear |
02-09-2014, 10:16 PM | #12 |
SYBIL
Drives: 2013 2SS/RS, silver ice metallic Join Date: Oct 2012
You can use any -6an rubber hose, should be able to get it at any auto parts store
02-16-2014, 04:47 PM | #13 |
Drives: 2012 Arctic White Camaro 1LS Join Date: Dec 2013
go to autozone, i used 3/8 inch radiator hose about 1 1/2 feet both ways with clamps on them and they work perfect
