03-29-2024, 08:54 AM | #1 |
Drives: 2011 Camaro SS Join Date: Feb 2024
HELP WITH ECM/TUNING PROBLEM? Controller Unlocker: Timed Out
Hey everyone,
I just finished installing a cam kit in my 2011 SS. Everything from the cam up is brand new (minus the heads). Remote tuning with HP Tuners I was running into some engine codes but talked to my tuner and it looks like the tune wasn't flashing fully. I had just been doing "write calibration" instead of "write entire" which was most likely the reason the tune file from the tuner wasn't getting written completely when we tried to flash it. This could have also been the reason for messing up voltage readings for at least the MAP sensor circuit (one of the DTCs I was getting). I went to flash the entire tune going through the normal process for that using HP Tuners (Using "Write Entire"). After the status "requesting access" it goes immediately to "Controller Unlocker: Timed Out" and says failed. After this I tried messing with the computer and HP Tuners (restarting the laptop, unplugging and replugging back in, unplug the tuner to shut it down and restart it, plugging it into the computer first, then the car and vice versa. I disconnected the battery and waited about 30 minutes before reconnecting it and tried that, I tired starting it with the battery on charge connected to power. I still kept getting the "Controller Unlocker:Timed Out" right away. At this point I thought, maybe I should try and start to crank the car and see if it reads. So I started scanning with VCM scanner and tried to crank it to get a reading. At this point the car wouldnt crank. I press in on the clutch to start it but the starter motor wouldnt even turn or crank the car. It would just turn the lights off on the dash as if I wasn't pressing the clutch in. The VCM scanner also started reading and scanning fine but I noticed it was only scanning the fuel rail pressure. I disconnected the battery and pulled the ECM fuse to do a full restart. After reconnecting it and putting the fuse back I was getting the same issue. - Car wouldn't crank and the same "Controller Unlocker: Timed Out" when trying to flash the tune. At this point I went to read the current tune that was on the car, but when I went to read it, it said No Vin was detected, please enter a Vin or Press Cancel to Continue. I pressed cancel to continue to pull the current tune on the car and also pulled it after typing in my VIN (pulled the tune twice). Both cases it pulled the same tune...there was no engine or trans data on the tune...only the fuel system would pop up with data (on fuel pressure). - Given all this. I've come to two conclusions. Either my PCM is bricked / fried, or somehow the tune got basically erased from the car, and it won't let me rewrite a new tune to it. I initially thought maybe when I started writing the entire tune, it erased everything and then only got part way into putting on the new tune (only fuel pressure got written) but when I try to write it, it only says "Controller Unlocker: Timed Out" which makes it seem like it didn't even start to write the tune onto the ECM. But at the same time, VCM scanner is still scanning and running with a connection so I don't think the ECM is bricked either. I also thought for a second maybe it is a lose ground connection to the PCM, but the car hadn't physically been moved or the hood even opened since the last time trying to crank/start it (the night before). - the battery was also at at least 12V throughout this whole process. I am not sure if anyone is familiar with what could be happening here, or if anyone has experienced something similar, but if you have any advice or input I would greatly appreciate it. I am at a loss on what to do now. I don't know how my ECM would have gotten bricked or fried but I hope I don't need to buy a new one. |
03-29-2024, 09:30 AM | #2 |
I'm not sure in this one but you might get some help on the HP Tuners forum from some of the guys over there. They are kind of clicky though so just be patient with them and do the steps they give you. Good luck sir.
03-29-2024, 10:06 AM | #3 |
I just posted on the HP Tuners forum as well! Thank you!
03-29-2024, 10:25 AM | #4 |
No reason at all to need to write entire for something as simple as cam tune.
03-29-2024, 11:15 AM | #5 |
Thats what I would think as well - I started with write calibration but it seemed like the tune wasn't flashing fully/correctly because there were engine codes appearing that would have been turned off in the tune. I have seen write entire be used before when changing the resolution for the MAP sensor having to do with the voltage /expected voltage. However even if I do "Write Entire" what would the reason for these problems be? Because it seems there is no tune on the ECU now and it wont let me write calibration or write entire either. It keeps giving me the Controller Unlocker: Timed Out
03-29-2024, 12:28 PM | #6 |
Have you tried the beta version of HP Tuners?
03-29-2024, 12:33 PM | #7 |
I haven't yet! I am thinking about trying beta or trying to go back a version and try that as well. I think that might be the next step after trying to disconnect the battery and trying to write again - although I am hesitant because I doubt changing the version would have much effect after writing many successful tunes on this version
03-29-2024, 01:43 PM | #8 |
I've had that message when trying to write with the key off by mistake
03-29-2024, 02:04 PM | #9 |
Ahhh I wish. I definitely had the key on unfortunately. I tried multiple times and tred messing around to see if anything would work to change it. Tried waiting 15 seconds, a minute, 5 minutes after key on
03-29-2024, 02:26 PM | #10 |
Are you running windows? If so, one dumb thing you can check for is pending updates & scan for updates. It probably wont do anything but I have seen this cause issues.
03-29-2024, 02:32 PM | #11 | |
This is really racking my brain. I might try to pull a bunch of fuses that could be generating noise, as well as cycle it (disconnect the battery) and see if that helps, and then keep writing until something happens lol. |
03-29-2024, 02:41 PM | #12 |
I like to try the most trivial things first. Maybe have your tuner resend the file & see if anything changes?
03-29-2024, 03:25 PM | #13 |
Drives: 2013 ZL1 Join Date: Sep 2021
If you email HP tuners Tech support they usually get back fairly quickly and they are pretty good at trouble shooting.
03-29-2024, 03:35 PM | #14 |
ecm, electrical, grounds, pcm, tuning |
