TireRack
Old 09-29-2019, 01:55 PM   #3067
205
Drives: 2010 Camaro
Relocation tips
Can anyone give me some hints on moving the ABS and fuse box? Locations? How to route? Where to cut, etc. I would really appreciate it as I only have the ABS mount to take off now. Thanks!
205 is offline   Reply With Quote
Old 10-02-2019, 11:20 PM   #3068
krusher
krusher's Avatar
Drives: 2010 Camaro SS/RS CGM
On the brakes:
Save the bracket that the ABS bolts to. I took some angle pieces and made a little table and welded it to the car where the filter box goes.
Some tips I got for you is buy nicop (nickle/copper) brake lines, they are so easy to bend and will not corrode. I first used steel ones from O Rielly's, I ended up finding nicop online and also at my local Arnold's. Also I will post a video of some AN fittings and bulk head fittings that I discovered on this video.
If you have some exposed areas the the nicop looks pretty trick too. Also I did buy some nice aluminum brackets for the brake lines. When attaching the brackets a rivet gun is awesome instead of using self taping screws. They show all that in the video and I got all the stuff from Jegs and Summit.
Lastly really sit back and think where you want stuff and what is your pain tolerance on maintenance. At first I had all the time in the world and I had all this stuff in the filter area. Bad part is that I had to take the whole panel off to change a fuse or anything.
I have moved the ABS twice and fuse box twice. If I did it over again I would have done now. I have the ABS in the filter area and my fuse box in the glovebox. I cut each "plug" from the fuse box and passed them thru the passenger side and then soldered them back together in the car. Make sure if you are going to do that really think that you need to do. You will need a new battery cable as the old one will not be long enough now. (can show pictures later). Make sure to label each plug and then do each plug at a time not all at the same time as your labels will fall off and get confused.
krusher is offline   Reply With Quote
Old 10-03-2019, 03:17 PM   #3069
205
Drives: 2010 Camaro
Thanks for that Krusher. Very helpful, and I do hope you add more photos. I thought about putting both in the filter hole. I already have the NiCo line, just waiting on fittings now. How do the wires pass through the passenger side to the glove box? I haven't looked that hard since tonight I am finishing plugging up the holes drilled out on the passenger side. Thanks again! Much appreciated
Old 10-03-2019, 08:26 PM   #3070
krusher
krusher's Avatar
here is my bay all finished
Name:  overview catch can.jpg
Fuse box cable routing:
battery cable routing from back to glove box. I had to cut a small notch out of the glove box to route correctly. I took the back seat out and a few of these side panels to route the cable.
Name:  battery cable.jpg
Brake line was ran from booster thru the cowl and had the ABS in the corner of the filter box. I also had the wire loom that went to the connector by the brake booster rerouted thru the cowl to clean the entire firewall as well.
Name:  brake line routing.jpg
Name:  finish filter bay.jpg
Old 10-04-2019, 12:59 AM   #3071
205
Drives: 2010 Camaro
Thanks for that. That is REAL CLEAN. Good job.
What size fittings are those? Flared? Bubble? I am so confused now. I don't know if they are metric (m10 x 1) or the 24 pitch. lol
Does the filter housing front just unbolt or did you cut it?
Old 10-04-2019, 07:02 AM   #3072
camguynj
camguynj's Avatar
Originally Posted by krusher View Post
Attachment 1006129
Attachment 1006136
Attachment 1006137
Attachment 1006133
Attachment 1006135
Attachment 1006134
Attachment 1006130
Attachment 1006131
Attachment 1006132
Absolutely awesome fantastic job I really like how clean it looks and your choice of colors and contrast. Couple of questions ...what coating is on the headers ,where are the coil packs, where did you terminate the positive battery cable from the trunk? Thanks
ps - love the dipstick
Old 10-04-2019, 10:50 AM   #3073
krusher
krusher's Avatar
I have two flaring tools, I robbed the flares off of the OEM lines and double flared anything that was factory connection like the master cylinder and the ABS module. Everytime I wanted to put them as an AN fitting I could never find one to match because it would be M10 or M12, but then the thread pitch would be wrong or the flare on the fitting would not be correct, so I finally relented on using the stock flare nuts and double flaring.
The AN fittings I chose for the bulk head fittings are a single flare 37 degree flare which is different than the regular double flare stuff. Below is an example of it. If you watch the youtube video I posted they have an example of the AN fittings. The ones you need are -3 and -4 AN fittings if that is the route you want to take.
https://www.speedwaymotors.com/Speed...Nuts,4149.html
Old 10-04-2019, 11:14 AM   #3074
krusher
krusher's Avatar
Thank you. The coating is Jethot Flat black. I am thinking about going with a mechanical Gunmetal satin gray to give them a little more shine and contrast the flat metallic silver of the bay.
I can take a picture if you need, but I just terminated it to the positive post right on top of the other battery cable so I have two cables connected to the positive terminal and then there is a channel that it rides in, you can see when you pull your trunk carpet up.
The coil packs are in the most painful spot imaginable, but it was the only place that was out of the way. They are mounted to the K member just in front of the oil pan. I then have them going to the spark plugs going up through the headers, but I have a 90 degree boot on them to hide them from the headers and direct it below the engine. This is not my engine below, but this is the look I went for, very clean not having the coil packs visible. The pain full thing is its is REALLY low and very tight.
Old 10-04-2019, 12:02 PM   #3075
camguynj
camguynj's Avatar
I think going with gunmetal satin grey on the headers would be a knock out, although they look pretty good now. Post a follow up pic if you do change them. GREAT job on hiding the coil packs
Old 10-04-2019, 01:49 PM   #3076
205
Drives: 2010 Camaro
I really like the contrast in colors too. I am just doing the boring body color. lol.
Does the cabin air filter front just unbolt? Or did you cut it? TIA
Old 10-04-2019, 04:02 PM   #3077
krusher
krusher's Avatar
The cover has two studs on the fire wall and originally one stud on the fender. It stuck out like a sore thumb so i cut it drilled it out and installed a rivetnut and chrome bolt. There is also a bolt near the top of the fender
Old 10-04-2019, 04:04 PM   #3078
205
Drives: 2010 Camaro
Ok. Thanks krusher! I finally got it off. That cover is in there pretty good
Old 10-04-2019, 08:06 PM   #3079
krusher
krusher's Avatar
Other thing I did was weld the seam together and ground the pinch weld and studs off and filled the cavities with a skim coat of bondo to smooth it all out
Old 10-05-2019, 12:07 AM   #3080
205
Drives: 2010 Camaro
Do you remember how the plastic cabin filter holder comes off? Looks like it will pop off, but I don't want to break anything
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 08:43 PM
New Texas Speed & Performance Engine Machining Center! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 01-16-2013 03:46 PM
Hawk Performance Brake Pads part HB247Z.575 $85.00 Rogan USA - Florida 2 10-07-2011 12:10 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
