AWE Tuning
Old 03-07-2017, 11:23 PM   #379
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by Michigan1LTRS View Post
Seems to be a GM test mule.
Spot on.
Old 03-07-2017, 11:29 PM   #380
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Originally Posted by libertyforall View Post
Seems absolutely absurd that the new 10-speed auto is not offered. Plain bone-headed move, GM!
What a beautiful car though!
At some point there has to be diminishing returns I would think. This thing is going to have plenty of power to pull a little lower RPM's out of a corner with a wider spread. My guess is that GM tested both and found little if no reason to run the 10AT at the limits and maybe it was actually less suited (less reliable) for heavy track use which I think a good amount of these purchased will be used for.
Eric SS is offline   Reply With Quote
Old 03-08-2017, 07:08 AM   #381
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
ILE package is always traditionally offered in manual transmission only.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten!
Bad@ssCamaro is offline   Reply With Quote
Old 03-08-2017, 08:21 AM   #382
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
I think they're only offering the manual to keep the price down and possibly to deter less track oriented owners from buying a car that really isn't a daily driver considering the tires and extra stiffness of the suspension. On the other hand; those in the know will be salivating over this option once the reviews start coming in.
DrkPhx is offline   Reply With Quote
Old 03-08-2017, 09:09 AM   #383
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
It's like Bad@ssCamaro said, the 1LE package is traditionally only offered in Manual. They could have easily offered this with the A10, but then it would not have been a 1LE. Al O and the Camaro team have proven that they feel very strongly about the 1LE package being manual only.
IG: @NC_M1SS1LE
FNxR3DNECK is offline   Reply With Quote
Old 03-08-2017, 10:33 AM   #384
Mr. Wyndham
It's also worth remembering...the ZL1 1LE weighs 124 lbs lighter than an automatic ZL1.
That is significant, and will surely result (coupled with the crazy-wide, grippy tires and aero) in increased performance beyond what is worth the added weight of the automatic.
I think there were several factors in the choice:
  • Maximum weight reduction without compromising interior comfort.
  • Less heat generated (not a problem, as we've seen...but still a factor).
  • 1LE "track car" appeal.
  • Simplified production combinations.
  • Lower cost ($2395 less, when including the gas guzzler tax).
Old 03-08-2017, 01:32 PM   #385
DrkPhx
DrkPhx's Avatar
^^^ All very good points especially on the weight difference. The fact they got the curb weight (which btw includes a full tank of gas) even lower is impressive. If my math is right; 60-3,886 (M6 car weight) = 3,826-lbs for the ZL1/1LE model. Subtract 57-lbs for a 1/2 tank of gas and you get 3,769-lbs. Wow, that's impressive for a factory super charged car. I know it's a road course car, but I would love to see someone throw some drag radials on this thing to see how it runs at the drag strip.
Old 03-08-2017, 02:49 PM   #386
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
It's coming!
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 03-08-2017, 03:55 PM   #387
Mr. Wyndham
Originally Posted by Sven59 View Post
It's coming!
Definitely!
The best part of the weight reduction is it's all in rotating and unsprung mass...wheels, tires, dampers...it will make for lightning-quick responsiveness to directional inputs, braking, and acceleration.
And they specifically list ZL1 1LE as 3820 (those 6 pounds help! )
Old 03-08-2017, 11:48 PM   #388
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Originally Posted by NB2017ZL1 View Post
They certainly will pick up road rash. Maybe their will be a type of wrap kit just for these.
htron50 is offline   Reply With Quote
Old 03-13-2017, 08:16 PM   #389
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
Wake me up when they offer the A10 with the 1LE package in either the SS or ZL1 trim.
JaxChris is offline   Reply With Quote
Old 03-14-2017, 08:51 AM   #390
Bad@ssCamaro
BeckyD Rocks :-)
Good luck with that sleeping beauty
Old 03-14-2017, 09:54 AM   #391
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
I was going to post the same thing with an apple, but didn't want to be a jerk
TLSTWIN is offline   Reply With Quote
Old 03-14-2017, 11:58 AM   #392
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
Originally Posted by Mr. Wyndham View Post
Definitely!
650hp/tq in a lighter lower stiffer package than my car with massive sticky rubber and extreme track aero.
My lease is up in 11 months.....
Thor142 is offline   Reply With Quote
