06-30-2022, 07:20 PM | #1 |
Drives: 2010 Camaro SS red Join Date: Aug 2014
15 Camaro SS key won't come out of ignition
When I put car in park key sometimes won't go back and release unless I hit automatic shifter toward frt of car then key will release out of ignition... is that maybe a adjustment under shifter? And how to or is it a new ignition switch? Thanks John
07-01-2022, 06:50 AM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Very common. There are many threads on here about it, just look around
10-14-2022, 01:54 PM | #3 | |
Drives: 2014 Camaro 1SS (A6 Ashen Gray) Join Date: Sep 2019
I encountered this issue. For me, I disconnected the solenoid that holds the key in place. Can't recall the specific process, but I know that it was easy, quick (15-30 minutes), and didn't require me to order any parts. I haven't noticed any issues as a result of the change.
If you do this, make sure that nobody ever pulls out your key while driving. It'll supposedly lock the steering wheel in place. Relevant forum post: https://www.camaro5.com/forums/showthread.php?t=567161 Edit: Here is a video that shows the process:
Mod list: GPI SS3 camshaft (VVT delete), ZL1 Fuel Pump, FIC 60 lb injectors, Tru-Cool 40k tranny cooler, Circle D 3600 triple disc (billet flexplate), GPI Rod Mod, Bo White ported TB, Variant Helium wheels, Continental ECS 02 tires, CAI cold air intake, Kooks 1 7/8" LTH w/ high flow cats, Ridetech HQ coilovers, BMR sway bars, BMR delrin subframe bushings, Hendrix offset poly diff bushings, Borla S-Type axle-back exhaust, Holley EFI Fuel Rails, Elite Engineering E2 catch can, Umbra LED Taillights, Kenwood DMX9707S head unit, some minor interior/exterior appearance mods.
10-14-2022, 02:58 PM | #4 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
I’ve had my shifter replaced once under warranty for this problem and it has started happening again. There are several potential workarounds and fixes, but I thought this was the best explanation and potential fix for the issue:
https://youtu.be/sETuCmaTLhY For now, I’ve been doing the following if the key gets stuck: 1) Turn key back to “on” position (don’t need to start the car) 2) Place foot on brake (car can stay in Park) 3) Squeeze the silver shift release button at the top of the shifter several times rapidly 4) Key should be able to be released at this point If this ever stops working, I will probably try the procedure in the video. Originally posted this comment here: https://www.camaro5.com/forums/showthread.php?t=609182 |
07-22-2023, 08:14 PM | #5 |
good to know for near future reference, mine is doing same thing
2015 2LT LFX 3.6L
FE2 Sport Suspension MXO-6 Speed auto w/Tapshift Aftermarket Oval mufflers |
07-29-2023, 11:19 AM | #6 |
Drives: 2014 Camaro 2SS Join Date: Apr 2022
Key stuck in ignition
So I researched the crap out of this. Installed a new ignition switch and didn't work. Found a useful video the take apart the shifter trim to get to the shifter switch.
https://www.google.com/search?q=cama...id:59kfjhXDF0Q Problem for me was the damn 25cent Chinese shifter switch is bad. I searched all over and can't find a replacement switch and it does not have a part number. As you can see I jumped the 2 wires but I don't like rigging things like this, especially when I give this car to my daughter. Started happening around 40,000 miles. Key comes out all the time but issue is you can be in any gear and remove the key. Only good thing is once in park and key is removed shifter stays in park. Was anyone able to find this piece of crap switch? Only other option is to spend $165+ for the entire shifter but a buddy of mine did that and 2,000 miles later he had the same problem. Last edited by ccbryson6161; 07-29-2023 at 11:54 AM. |
07-30-2023, 07:30 AM | #7 |
Drives: 2013 ZL1 Join Date: Sep 2021
Thats called a limit switch/micro switch you will probably have to modify one depending how it mounts. Don't worry about AC or DC ratings just amps.
https://www.amazon.com/MXRS-Hinge-Mo...ps%2C97&sr=8-4 https://www.amazon.com/dp/B07P4CJ8TV...1-df67fc737124 |
