Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
BeckyD @ James Martin Chevy
Old 02-28-2020, 09:04 AM   #1
aj0294
aj0294's Avatar
Drives: 2018 Camaro 2SS
Sport and Track Mode Vibrations
Please help, I recently took my 2018 2SS (manual) on a drive and noticed a slight vibration upon entering sport mode. After noticing the vibration, I felt the same issue in track mode, just a little more aggressive. The vibration is intermittent but is mostly felt when initially entering Sport and Track mode. I took the car to a dealer for diagnostic but they couldn't find anything.
Some more details on the issue: only felt at speeds between 60 - 80 mph (1500 - 2000 rpm), high frequency vibration, low frequency sound, vibration still occurs while car is coasting in neutral (between 60 - 80 mph), and vibration is not evident when vehicle is stationary at same rpm range. The vibration is intermittent (but rare) in touring mode and is non existent in snow/ice mode.
If you have any ideas, please shoot them my way. I've been trying to figure this out for the past couple days now.
aj0294 is offline   Reply With Quote
Old 02-28-2020, 07:57 PM   #2
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
If it's most audible when entering sport or track mode and comes on intermittently, I bet it's the one or both NPP valves squeaking or vibrating inside the outer exhaust pipes when being opening or closed. They're opened even in tour mode, but only under high load, and remain closed in snow/ice mode.
There is a TSB out for a potentially related exhaust rattle concern (number 18-NA-172), but it's hard to tell if you have this or something else, it would help if you could record it and upload a clip somewhere.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 03-14-2020, 06:38 AM   #3
Just.an.ss
Drives: 2018 Camaro 1SS
https://youtu.be/J2AvrPv_pNc
I have a slight problem with mine as well. No vibrations but a buzzing winding noise when accelerating I’m not sure what it is
Just.an.ss is offline   Reply With Quote
Old 03-14-2020, 08:07 AM   #4
arpad_m
arpad_m's Avatar
This is different from OP's problem. Mine has been making the same noise to be honest, from day 1, a not too loud, but definitely present winding down sound. Adding a supercharger doesn't fix it, that I can tell. Will let you know if I figure it out, I hardly notice it anymore.
735 rwhp | 665 rwtq
manual, shudder, sport, track, vibration
