Old 09-12-2019, 12:12 AM   #1
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
TOYO PROXES RR slicks
Just noticed these, they are only $250 per 295/30/19 at Tirereack, does anyone have any experience with them or know anything about them?
https://www.tirerack.com/tires/tires...PXRR&tab=Sizes
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 09-22-2019, 06:23 PM   #2
kdm123
Drives: 2018 ZL1-1LE
I found some for $140 a tire on a discount site and bought all 5 that they had available. I think these tires are discontinued which is why they are being sold cheap. Even Walmart has them--but only in 18s.
kdm123 is offline   Reply With Quote
Old 10-09-2019, 11:51 PM   #3
1LE76G
Drives: 2017 SS 1LE
Try them out yet?
1LE76G is offline   Reply With Quote
Old 10-10-2019, 09:47 AM   #4
Rodan
Rodan's Avatar
Drives: 2018 ZL1 coupe
I love these on our Miata track car, but have no experience with them on heavy, high HP cars.
Something to think about: 295/30-19 is 1.3" shorter than the stock ZL1 rear tire and .7" shorter than the stock ZLE rear. That's a LOT.
Rodan is offline   Reply With Quote
Old 10-10-2019, 12:46 PM   #5
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Something to think about: 295/30-19 is 1.3" shorter than the stock ZL1 rear tire and 1.2" shorter than the stock ZLE rear. That's a LOT.
Better check your math on the ZLE tire
TheRealJA105 is offline   Reply With Quote
Old 10-10-2019, 01:07 PM   #6
1LE76G
Drives: 2017 SS 1LE
They're within a few tenths of an inch from the 305/30-19 RE71s
Old 10-10-2019, 02:33 PM   #7
Rodan
Rodan's Avatar
My mistake... .7" shorter than the stock ZLE rear. Still a significant difference.
Old 10-23-2019, 11:52 PM   #8
GunMetalGrey
Read lots of similar reviews on tirerack, nobody seems to have used them on camaros or mustangs
Old 10-25-2019, 10:19 AM   #9
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
I was planning on buying a set for track use but really didn't want to lose the tire width, and ended up on 305 front Bridgestone RE-71r's and 355 rear Kumho ACR's and am very happy with the grip.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 10-26-2019, 01:41 PM   #10
GunMetalGrey
Originally Posted by ICTsccaCamaro View Post
I was planning on buying a set of track use but really didn't want to lose the tire width, and ended up on 305 front Bridgestone RE-71r's and 355 rear Kumho ACR's and am very happy with the grip.
Interesting combination, how do they compare to your stock tires on the track so far?
Old 11-26-2019, 07:36 AM   #11
2018$S1le
2018$S1le's Avatar
Drives: '19 ZL1 1LE Summit White M6, PDR
Could you throw some pics up of the 355s?
2018$S1le is offline   Reply With Quote
proxes, slick, toyo, track
