Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
Old 06-12-2017, 09:12 PM   #1
Hot2016Red
Drives: 2016 2SS
USB Ports not working
Has anyone had any issues with the two USB ports in the center armrest not working? Cannot get a thumb drive or my IPhone working with CarPlay when I plug in.
Hot2016Red is offline   Reply With Quote
Old 06-12-2017, 09:30 PM   #2
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
Check the cable you're using when connecting the iPhone. I had some issues and it turned out the cable wasn't sufficient.
Inspector 17 is offline   Reply With Quote
Old 06-12-2017, 10:02 PM   #3
MotownBoy
MotownBoy's Avatar
Drives: 2017 2SS Stick Hyper Blue
I feel your pain, Brother.
See this link:
http://www.camaro6.com/forums/forumdisplay.php?f=228
MotownBoy is offline   Reply With Quote
Old 06-13-2017, 01:51 AM   #4
Spazeack
Drives: 2023 2SS1LE
i am having the same issue as well however just on one of the 2 usb ports.
Spazeack is offline   Reply With Quote
Old 06-13-2017, 09:50 AM   #5
Klayman
Klayman's Avatar
Drives: 2017 2SS A8 Black
Every once in a while I get a "media not found" error. I unplug my USB and wait a minute, then plug it back in, maybe I switch which plug. That usually does it.
Man is born free, and everywhere he is in chains
Klayman is offline   Reply With Quote
Old 06-13-2017, 11:11 AM   #6
TripleB
SoCal Mayhem
TripleB's Avatar
Drives: 2017 2LT Hyper Blue Metallic Camaro
I have that issue sometimes too. It also happens in my Stingray. I've always chalked it up to MyLink issues.
TripleB is offline   Reply With Quote
Old 06-13-2017, 01:09 PM   #7
MotownBoy
MotownBoy's Avatar
Try this type of USB devise: SanDisk
A couple guys here recommended it. I suspect it is the Silver Bullet.
I've ordered a couple.
Old 06-13-2017, 01:11 PM   #8
Stryfe
Make America Fast Again
Stryfe's Avatar
Drives: 2016 HBM 1SS - M6
I have this issue. The dealer installed my spectrum lighting kit incorrectly and my car is full of little wiring bugs. Working on getting it sorted out in July.
Stryfe is offline   Reply With Quote
Old 06-13-2017, 01:24 PM   #9
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
I use these in 32Gb, never had an issue.
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 06-13-2017, 01:54 PM   #10
Hot2016Red
Drives: 2016 2SS
Thanks for advise. Just disconnect the negative cable for about 15 minutes and it reset itself. USB working again. Easy fix.
Old 06-13-2017, 03:32 PM   #11
TripleB
SoCal Mayhem
TripleB's Avatar
It even does it with my iPhone though. CarPlay shows up on the screen and when you touch it, it doesn't open. It's weird.
Old 06-13-2017, 03:36 PM   #12
Oil Man
Oil Man's Avatar
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2)
I get this too. In my case, it's usually another Lightning cable going bad. They're extremely sensitive to flexing and twisting, and as I still haven't found a satisfactory mount for my 6s plus, the phone usually slides around on the passenger seat while I drive. The lifespan for a cable in my house is probably about 4 months.
Oil Man is offline   Reply With Quote
Old 06-13-2017, 04:21 PM   #13
TripleB
SoCal Mayhem
TripleB's Avatar
i put my phone in the cup holders sideways...definitely need to find another spot for it for when i have drinks.
