Old 10-16-2013, 11:49 AM   #1
kcox2010
synergy2011
kcox2010's Avatar
Drives: 2011 synergy green 1ss/rs
Send a message via AIM to kcox2010
Zl1 pedal covers??
Need help Install new zl1 brake and clutch pedal cover tried bake and heat and no luck very aggravated
2011 synergy green ss/rs,rally stripes
kcox2010 is offline   Reply With Quote
Old 10-17-2013, 12:34 AM   #2
Dr.Spike
Dr.Spike's Avatar
Drives: 2013 Camaro ZL1 (IOM)
Try soaking the covers in hot soapy water before trying to install them.
Dr.Spike is offline   Reply With Quote
Old 10-21-2013, 07:36 PM   #3
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
I used a very small, thin screwdriver and WD-40. Sprayed the rubber on the inside and coated screwdriver. Work 3 sides in (bottom and sides) and then work the tiny screwdriver in the top corners to pry the rubber end on the top up and over and work it to the middle...doing a little kind of crow bar action while pushing up at the bottom of the pedal to let it have a little "give".
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
Old 11-02-2013, 01:07 AM   #4
RatedZ
RatedZ's Avatar
Drives: Camaro SS
I tried several suggestions and I found that the brake (and clutch) covers are rubber with a metal plate over them that is glued. I simply dipped them in hot water, seperated the rubber cover from the metal cover, installed the rubber cover in 10 seconds and reglued the metal cover. It was super simple.
RatedZ is offline   Reply With Quote
Old 04-03-2014, 09:41 PM   #5
domano 68
domano 68's Avatar
Drives: 2014 1LE
What type of glue did you use?
domano 68 is offline   Reply With Quote
Old 04-04-2014, 02:11 AM   #6
RatedZ
RatedZ's Avatar
Drives: Camaro SS
Gorilla Glue Gel. Been on for a while with zero issues.
Old 04-04-2014, 08:40 AM   #7
domano 68
domano 68's Avatar
Drives: 2014 1LE
Cool, thanks!
Anyone who is getting these pedals, separate the aluminum cover from the rubber pad by heating with hair dryer - then slowly remove aluminum from rubber - put rubber pad on pedal - then re-glue aluminum on installed rubber pad. 100% easier!! Using this method makes the gas pedal the most difficult of the 3 pedals by far.
Old 08-14-2023, 07:51 PM   #8
mikes02ls1
mikes02ls1's Avatar
Going to try separating the metal from the rubber. Cause these pedal pads are whooping my ass. Tried lube on the inside and small flat head and no luck. Ugh
2010 Camaro 2SS. Triple black and slow at the moment. Lowered with a 1LE 3.91 gears, brake cooling ducts. It’s a canyon carver.
mikes02ls1 is offline   Reply With Quote
Old 04-11-2024, 12:04 PM   #9
Pxk15
Drives: Camaro 2SS/RS
ZL1 Pedals
I know this thread is dated, but any tips on how you installed them? I just ordered a set.
Thanks
Pxk15 is offline   Reply With Quote
