Roto-Fab
Old 09-22-2012, 09:57 AM   #1
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Coding your GM locking gas cap DIY
*EDIT*
This cap is now replaced with GM part # 23159210
The price has increased to around $50 online.
So There are several threads about this gas cap and having it coded by a dealer for $50, or having a locksmith do it.
If you dont have extra cash or your key code you can follow my instructions and get it done in less than 10 minutes.
For those of you that do not know, this cap works with your existing side cut key. About $22 from dealer, $15 or less online
GM part # 22790846
AC Delco # GT344
The tumblers are listed as 1L, 1R, 2L, 2R, etc. these are left or right specific.
One side of the lock cyinder has 2 keyhole slots and one has 3. The side with the 3 keyhole slots is the LEFT side.
There are 2 tumblers per side, the 3rd one on the left side is for the brass retainer clip.
Grab one tumbler that has a L in it and insert it into the first keyhole slot.
Hold the tumbler centered in cylinder and insert your key all the way.
Slide the sleeve (tab end first) over the cylinder.
If it stops at the tumbler it is the wrong one. (pic below)
If correct it should slide all the way up and rotate 90 degrees.
Once first position is correct leave it in and repeat for other left tumbler.
Then find both right side tumblers the same way.
Now carefully remove each tumbler and remember its location.
(the 5,6,7,8 below is the order of the cut positions if you get the code from the dealer)
Insert 2 springs (I did right side 1st)
Insert tumblers.
Repeat for left side.
Insert your key, and slide over the cylinder sleeve.
Make sure it rotates smoothly.
If everything is good insert the last spring and the brass keeper till it clicks in place.
Check for full operation one last time. Once you install the cylinder into the cap it will not come out.
Align the 3 tabs in the cap, and the 3 grooves of the cylinder.
Press together, till it clicks. You may have to rotate the handle, while holding the white part of the cap. Make sure you get those 2 tips on the end of the cylinder to line up.
Insert key, and test.
Thats all, its pretty easy.
GVA 45TH 2SS is offline   Reply With Quote
Old 09-22-2012, 10:29 AM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
You're pics aren't working for me.
Old 09-22-2012, 10:39 AM   #3
GVA 45TH 2SS
KNGTFALL
They should be up now.
Old 09-22-2012, 12:54 PM   #4
t!mbo
t!mbo's Avatar
Drives: 45th 2SS M6
Nice Writeup, great info!
t!mbo is offline   Reply With Quote
Old 09-22-2012, 05:39 PM   #5
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
When I saw all the parts that come in the bags I was worried, but getting them togther was really easy. Good job with the pictures. I have had mine for over a year and this keeps me from leaving the keys in the car when I fuel up.
MMC is offline   Reply With Quote
Old 09-22-2012, 07:16 PM   #6
GVA 45TH 2SS
KNGTFALL
Thanks,
I was worried about trying it myself, but I ordered it anyway.
When I figured it out, well I decided I had to show others how easy it can be.
The hardest thing was holding the tumblers in place while adding more.
Old 09-22-2012, 08:46 PM   #7
DeAdMiKe187
Drives: Black 2012 2LT
Nice.
DeAdMiKe187 is offline   Reply With Quote
Old 09-24-2012, 01:15 PM   #8
NinerSS
NinerSS's Avatar
Drives: 2011 Camaro 1SS
Great write up. I'm planning on doing this real soon.
NinerSS is offline   Reply With Quote
Old 09-25-2012, 12:12 AM   #9
khalsa013
Drives: 2ss & ZL1
Send a message via AIM to khalsa013 Send a message via Yahoo to khalsa013 Send a message via Skype™ to khalsa013
sweet! too bad i already have the defenderworks cover
khalsa013 is offline   Reply With Quote
Old 11-16-2012, 11:42 PM   #10
rzrbck_zl1
rzrbck_zl1's Avatar
Drives: '13 ZL1 CRT #702; '05 Hemi Ram
Thanks for the pics. Very helpful!
rzrbck_zl1 is offline   Reply With Quote
Old 11-17-2012, 02:53 AM   #11
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
wow never knew this existed from GM... will purchase soon!
BronxxBombers213 is offline   Reply With Quote
Old 11-17-2012, 12:21 PM   #12
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
I just did this not 10 minutes ago. Easy peasy. And it DOES fit 2010s for anyone wondering like I was. (book doesn't show it fitting 2010 for some reason)
Just a couple of notes. The pin holding it onto the cap can be a mofo. It's plastic and will pop off, but you may mangle it if you're not careful. I almost did.
Also, obviously since it has more moving parts, it's heavier than the original cap by far, so be careful not to let it drop when you're removing the key so it doesn't clunk the quarter panel. More potential for damage.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 11-17-2012, 04:30 PM   #13
GVA 45TH 2SS
KNGTFALL
[QUOTE=el ess X;5818213]
Just a couple of notes. The pin holding it onto the cap can be a mofo. It's plastic and will pop off, but you may mangle it if you're not careful. I almost did. QUOTE]
Yeah I didn't talk about removing the strap to the door. Your on your own there
Old 11-29-2012, 11:49 PM   #14
DrewJitsu
DrewJitsu's Avatar
Drives: ZL1, 2012 3500 Duramax Dually 4x4
Thank you!
DrewJitsu is offline   Reply With Quote
