Roto-Fab
Old 07-15-2022, 08:22 AM   #15
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Lol I didn't realize I was in this forum, I must have clicked on it by mistake as I do not normally visit this one.
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 09-01-2022, 04:24 AM   #16
UnbecomingTV
Drives: Camaro Gen5 2009
So a new updade for you guys, after ordering the Thermostat and the Intake Mainfold Gasket, driving to the Workshop he Told me that this pipe and an other pipe were also leaking.
Originally Posted by UnbecomingTV View Post
... On Saturday he called me and said the pipes going from the engine to the heater was leaking a bit ...
And also This Pipe
So now everythis is done now and I've driven for two week now with no problems, but i have the feeling this isn't over jet. I have the clue that the Heater Core is also leaking a bit and this yould be very expensive to repair.
But I'll keep you updated on it
UnbecomingTV is offline   Reply With Quote
Old 09-01-2022, 08:02 AM   #17
Joe.G
Joe.G's Avatar
Why do you think the Heater core is leaking? If you are still smelling antifreeze I have found that Dex Cool can smell for a while after the leak even if it was cleaned well.
SCT X4 Dynosteve,
Old 12-12-2022, 10:10 PM   #18
talltom
talltom's Avatar
Drives: Silver LS
update?
Hi Unbecoming,
Following your post since I am having an increase in operating temps recently. My mechanic suspects the thermostat, but the repair is about $450. Since the operating temp isn't acutally overheating (212F) I continue to drive it. But I'm not taking long trips and I monitor it closely. I have 216K miles and worried about those heater pipes and core as well. Let me know if you are happy with the thermostat replacement.
Silver LS - manual, white stripes, black interior, and those swell 18" black steelies! (18" Bavarian aluminum in the garage).
talltom is offline   Reply With Quote
Old 01-14-2023, 05:20 PM   #19
TooCool5
TooCool5's Avatar
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP
If its worth anything, my radiator cap failed and was leaking, Take it off and check the bottom O-ring, if its flattened replace it.
It was not keeping the proper pressure / fill level.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
TooCool5 is offline   Reply With Quote
coolant leak, overheat, overheating
