Old 09-13-2023, 08:10 AM   #1
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
Engine blew new build
Wanting to get some opinions on the build.
L8T block (for future proofing)
400 Cubic inches
10.5:1 compression
Forged rotating assembly (callies crank and rods, diamond pistons)
Plan for the car is stock blower for now but going to a 2650 in the future
Nimair.ZL1 is offline   Reply With Quote
Old 09-13-2023, 08:37 AM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
400 Cubic inches
10.5:1 compression
Could you call your neighbor LME and talk with them
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 09-13-2023, 09:02 AM   #3
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
400 Cubic inches
10.5:1 compression
Are you trying to make 1000 or 2000hp? Is something wrong with your current block? L8t block is nice for strength but it adds another 100lbs over a lt1/l86 aluminum block.
I have an l8t crank in an Lt1 block and the extra torque helped offset some turbo lag with my stock converter. PD blower is going to amplify that torque.
Scoggin Dickey is also in TX and very big in the L8t game, wouldn't be a bad idea to give them a call, see what they say. They're who I got my crank from.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels
1.45 4.01 6.07@120.74 9.28@153.43
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild
jlaudio11 is offline   Reply With Quote
Old 09-13-2023, 09:26 AM   #4
Z OH 6
Drives: 2021 Red Hot ZL1
You have a blown engine in a 2023 ZL1 already? What the heck happened?
Z OH 6 is offline   Reply With Quote
Old 09-13-2023, 09:33 AM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
This ^
WhiteMale is offline   Reply With Quote
Old 09-13-2023, 09:36 AM   #6
Nimair.ZL1
Well there was white smoke coming out the tailpipes and the coolant reservoir was dry. Looked at the bottom of the car and there was oil dripping from flange where the header meets the off road connection pipe. Car takes a while to crank up and start but it runs like utter shit like its down a cylinder. Assuming it's blown tbh. Hoping for the best the preparing for the worst. Should know exactly what's wrong this weekend
Old 09-13-2023, 09:52 AM   #7
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
600 shot of nitrous?
CalgaryZL1 is offline   Reply With Quote
Old 09-13-2023, 09:54 AM   #8
Nimair.ZL1
Nope. Cam, headers, lower pulley, catch can, e85
Old 09-13-2023, 10:08 AM   #9
Z OH 6
OK, so it wasn't stock. That explains a lot more. Sounds like something went wrong with the build. Hope you're using a different shop for the rebuild.
Old 09-13-2023, 10:08 AM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
It would make blue smoke if the engine is hurt
'20 ZL1 1LE A10,
Old 09-13-2023, 10:08 AM   #11
Nimair.ZL1
Lol it was the stock block and rotating assembly
Old 09-13-2023, 10:10 AM   #12
Z OH 6
Stock block and rotating assembly wouldn't have went out if it was built correctly, those mods are very mild and people use the stock block all the time for MUCH wilder builds without issues. This was very likely a bad build or tune issue.
Old 09-13-2023, 10:17 AM   #13
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Oh damn I think I saw the video and the datalog from your car. Were you logging when it blew? My biz partner sent me a video and a datalog from a ZL1 that just popped in Texas.
Megahurtz is offline   Reply With Quote
Old 09-13-2023, 10:25 AM   #14
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
GM will cover everything under warranty, no problem.
But seriously, I would be having a heart to heart conversation with whoever did your build. That's seriously messed up on a brand new car.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
