Old 04-09-2013, 08:38 PM   #1
bostonfp12
bostonfp12's Avatar
Drives: 2012 2lt rs
Question Paddle shifters
On Sports mode(automatic) for paddle shifting at what speeds should i change gears. Example 1st is in between 10-15mph. theirs 6 in total
bostonfp12 is offline   Reply With Quote
Old 04-09-2013, 08:44 PM   #2
Hyena
Drives: 2013 1LT RS CRT
depends on the type of driving your doing.performance driving you shift it higher in the rpm range...around town driving,shift it where it sounds good.don't worry about the trans...it won't let you do anything too stupid....
Hyena is offline   Reply With Quote
Old 04-09-2013, 08:49 PM   #3
bostonfp12
bostonfp12's Avatar
Drives: 2012 2lt rs
Its usually city miles. isnt their specific guidlines as far as mph that i can follow besides "when it sounds good"
Old 04-09-2013, 09:04 PM   #4
samhardy2008
samhardy2008's Avatar
Drives: 2012 3.6 camaro
just pay attention to your rpms more than anything
samhardy2008 is offline   Reply With Quote
Old 04-09-2013, 09:49 PM   #5
Denis
Denis's Avatar
Drives: 2010 SS
ummmm shift when you want to. no real science to it....as long as the tach doesnt read 9000 you should be okay
Denis is offline   Reply With Quote
Old 04-13-2013, 10:17 AM   #6
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
The rev limiter will catch it way before then...
I have actually forgotten I had it in manual mode and tromped it and hit the rev limiter a few times. But has only happened since I changed the exhaust out....
The Bird is the word!
Old 04-13-2013, 10:28 AM   #7
cam62
Drives: 2012 IBM Vert 2SS/rs
I hear you. It's a bit embarrassing when you know some people watching. Lol
rx catch can;vmax ported throttle body;bowtie delete;SLP SS emblem;CAI cold air intake
cam62 is offline   Reply With Quote
Old 04-13-2013, 11:01 AM   #8
Ringo64
Forever Pontiac
Drives: 2012 Black 2SS/RS
It's RPMs not speed that you should be watching and matching those to your driving style. Usually for city driving I would shift around 3k.
Ringo64 is offline   Reply With Quote
Old 04-13-2013, 11:07 AM   #9
skibik
Guest
Drives: bbbbbb
I see I am not the only one that has done that. Had it in sport mode coming home from work after I first got it. Passed a few cars before I got home. Stopped at a stop sign stepped on it and as it hit the limiter I was thinking what is going on, why isn't it shifting. Re-read the manual and didn't realize it will downshift but not upshift. Even after I read the manual I still have done it because of my short term memory. I myself will put it in S mode and not even use the paddles because it shift more aggressively when I get on it. If I use the paddles I shift at whatever RPM I feel like it at the time. It won't let you upshift if the RPM is too low and on the other end the rev limiter will stop you. When I am done horsing around with the paddles in S mode I usually pop it into D right away. I even use the paddles in D sometimes when I pass someone so I don't have to step on it so hard to get it to downshift.
Dean.
skibik is offline   Reply With Quote
Old 04-13-2013, 11:14 AM   #10
Angrybird 12
Dean.
You know when in manual you can hold the right paddle for a few seconds and it return to sport mode without manually shifting to D.
Old 04-13-2013, 11:47 AM   #11
skibik
Guest
Drives: bbbbbb
Really, I did not know that. I guess I learned something new today.
Thanks, I will have to give that a try.
Dean.
Old 04-13-2013, 03:01 PM   #12
TJR1952
TJR1952's Avatar
Drives: 2013 2LT
For good gas milege shift when you are about to reach 2000 rpm. For performance run it all the way up to 6500 rpm.
TJR1952 is offline   Reply With Quote
Old 04-13-2013, 03:46 PM   #13
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Shift speeds (rpm) is dependent on acceleration.
If you're just cruising along, you might shift at 2500 rpms. But if your running wide open hauling axx, you'll want to shift close to red line.
SGOS252382 is offline   Reply With Quote
Old 04-13-2013, 06:55 PM   #14
bostonfp12
bostonfp12's Avatar
Drives: 2012 2lt rs
Thanks to those last two responses
