08-30-2014, 03:31 PM | #1 |
Drives: 2010 2LT/RS 6A Join Date: Aug 2014
Just bought a Camaro today !
It is a 2010 RS 2LT package, 29,000 Miles .
Paid $18,200 Out the Door. Is that a fair price ? the only thing is the drivers side headlight is burnt out, do you really have to take the whole front fascia off to change the bulb ? Or is there an easier way ? I checked youtube and that's the only way i saw |
08-30-2014, 03:32 PM | #2 |
Drives: SS2 Join Date: Aug 2014
nice!
08-30-2014, 03:39 PM | #3 |
Drives: '14 RRM 1LT/RS A6 Join Date: Mar 2009
Nice man! You got a loaded 2LT for a pretty good price! Looks clean!
08-30-2014, 03:41 PM | #4 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Nice and low mileage. Price varies with options and condition.
You saved yourself a ton of depreciation over new. As long as your happy it was a deal.... Enjoy.
08-30-2014, 03:41 PM | #5 |
Thanks. Yeah I'm happy with it, leather, paddle shif/sport, remote start, RS package, and 31.8 mpg the whole 3 hr drive home
Anyone know about changing the headlight ? Does the front fascia have to come off ? Or is hat only if your taking out the whole assembly ? |
08-30-2014, 04:06 PM | #6 |
Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
Next, remove the inner plastic fender liner by removing all of the the plastic push-pin fasteners using a flat blade screw driver. Slide the screw driver blade under the the head of the push-pin & pull it out untill it stops. You then can get under the bottom flange of the fastener & pull it right out. After you have removed all of the push-pin fasteners, you can remove the inner plastic fender liner. You will then have access to the back side of the head light assy. & then you can remove & replace the bulb. Do NOT even think about removing the front wheel, untill the car is blocked up! Check your owners manual for the correct bulb. Also, your local Chevrolet dealer service department can help you with getting the correct bulb as well as gaining access to the bulb. Hope this helps. I also will not be held responsible for ANY of the above information. Orange 2010 Camaro Also I forgot to mention, you will also have to remove a few #20 or #25 Torx head screws as well. Hope this helps. Last edited by Orange 2010 Camaro; 08-30-2014 at 06:07 PM. |
08-30-2014, 04:14 PM | #7 |
Drives: 2008 VW R32, 2011 Synergy Green 2SS Join Date: Jul 2010
If you just bought it today, why don't you take it back to the dealer you got it from and tell them and have them fix it?
08-30-2014, 04:26 PM | #8 |
Drives: Really Slow Join Date: Apr 2010
if it's just the bulb, you can replace it without taking the bumper off.
http://www.camaro5.com/forums/showthread.php?t=192343 video of how to remove bulb. it's off the car, but doesn't need to be.
08-30-2014, 04:36 PM | #9 |
SoCal C5 Family Member
Drives: 1996 Z28 SS & 2014 ZL1 Join Date: Apr 2009
First, I would see if the dealer will replace the headlight bulb.
If they don't, you can replace the bulb yourself, and you will not have to take the front fascia off to do this. All that you need to do is remove the domed black back cover at the back of the headlamp assembly (all it takes is a quarter turn to remove it). Instructions: Headlamp Bulb Accessory Cover: Rotate the cover a quarter turn counter-clockwise and remove from the headlamp assembly. Headlamp Bulb Assembly Procedure: 1. Disconnect the electrical connector from the bulb socket. 2. Rotate the bulb socket counterclockwise and remove from the headlamp assembly
Vance Chula -
1996 Camaro Z28 SS #1688 2014 Camaro ZL1 Coupe #1956 |
08-30-2014, 04:40 PM | #10 |
Drives: 2018 2SS Hot Wheels Convertible Join Date: Dec 2012
08-30-2014, 04:40 PM | #11 |
Emerald Archer
Drives: 2011 2SS/RS Synergy Green Metallic Join Date: Jun 2014
Beautiful, congrats!
08-30-2014, 10:21 PM | #12 |
Drives: 2010 RJT 2SS M6 Camaro Join Date: Feb 2011
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
08-31-2014, 12:01 PM | #13 |
Drives: Current Camaro-less Join Date: Jul 2014
Wait..
You bought it from a dealer..and they had not previously replaced the burned out bulb before sale? If it was private party okay..but I would still expect to pay at least $200 to have it done at a approved Chevy dealer. |
08-31-2014, 12:42 PM | #14 | |
Drives: 2014 1LT Join Date: Jan 2014
Congrats on your new car!
Found this on You Tube for you hope it helps- |
