dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 01-01-2015, 11:33 PM   #1
forklord
forklord's Avatar
Drives: 2010 2SS
new build for roadcourse....
Hey Guys. So i'm planning on trying the roadcourse when i move to the city. I'm getting a little discouraged by a lot of people cuz i have a supercharger. was gonna upgrade the oil cooler, rads, add a diff cooler, etc but im still not comfortable with it. im a total newb at racing and sure everyones gonna tell me to try it before i sell my s/c and build my engine....but anyway...
it will be somewhat of a budget build so im wondering if i should machine my ls3 to a 416/418 forged and get my heads milled/polished a little and do the rest myself. it will very much be a daily driver in the summer only, but i really want to hit the track. id like to sit at 550whp at LEAST...would i keep the id850s and zl1 fuel pump? dry sump? will i still need to upgrade cooling regardless? will i need 3.91 gears?? /cry
the main questions tho are what pistons/rods/rings/etc will i need with a 5-6k budget and is it even possible..... am i better off selling the whole engine, s/c and all, and getting a turn key? i think an lsx/ls7 block is out of my range lol....would be nice
if anyone has any similar build journals on here to recommend id like to see em. thanks!
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 01-02-2015, 12:19 AM   #2
trackwhore
Drives: 06 Z06
best and easiest thing to do is. Get a oil cooler or oil/rad/dif cooler. Go out and drive your car. Throwing a bunch of parts at your car before you work on the driver mod is not the best idea. Go out have fun. If you blow it up. Then you will know what you need to mod. Some people with stock cars drive fast. They are good drivers. Go out and do a track day and get a instructor to help with your driving. Then its all about seat time. I need more seat time too.
trackwhore is offline   Reply With Quote
Old 01-02-2015, 02:04 AM   #3
Synner
Drives: cars
I would get an IAT gauge, real brake pads, and radiator first. Then seat time. A BIG oil cooler with thermostat would be shortly after that.
You don't need the gears, it'll only make you shift more, with that power. At this point just have your tune gone over and make sure its very conservative from a timing and AFR standpoint. Some shady tuners also turn down knock sensors a lot. Forced induction adds more risk on a road course for the motor so gauge monitoring is very important. Thats why most road course builds stay n/a.
Synner is offline   Reply With Quote
Old 01-02-2015, 04:45 AM   #4
X25
X25's Avatar
Drives: '16 C7 Z51
It will be hard to keep all temps in healthy ranges with a supercharger. You'll need all the cooling you can get, and oil cooler upgrade might also become a necessity. As was advised, gauges to check on oil, air temps would also be very important to monitor vitals, at least until you know how your car behaves in various driving and environmental conditions.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 01-02-2015, 08:04 AM   #5
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2022 SS 1LE
All good advice from the guys above.
The biggest challenge to a road course build is making the engine and drivetrain survive multiple seasons and not cook on a hot track day. I've noticed that my more experienced track rat friends tend to leave their motors nearly stock for that reason. Forget about at least 550 WHP, you'll be breaking stuff left and right. If I were to do it all over again I'd just get a Z/28 and do longtube headers, a tune and a serious oil cooler.
And as others have stated, oil temp is a weak link in the Camaro. I'm adding dual oil coolers to try to get it cool enough. I think a supercharged LS3 would be a real challenge in this regard.
I also think your budget is low unless you go really mild on the build.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 01-02-2015, 11:43 AM   #6
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
I would dial that boost back as far as possible, with whatever pulleys that might require (I really don't have a feel for what a 3" pulley is worth, but for the track right now even 450 crank HP is more than you should be trying to use all of). Consider any milder-power tuning options that may be available. In addition to taking the suddenness out of the throttle response that won't be your friend as you're trying to gradually add throttle on corner exit, that should also alleviate the heat issues at least a little via less intake air compression heating.
3.91's are the wrong way to go at this stage in one's track day development. Strongly consider driving about one gear higher anyway, at least until you have good familiarity with the line you need to be on and how much/little throttle you can actually use there. Having the power roll on even slower will be a plus because you'll be able to focus on learning the new (to you) skills involved. Yeah, it may feel a little "doggy" compared to what you may have become accustomed to, but you'll be better off for it guaranteed. Never mind that your instructors' comfort levels can't help but benefit when nothing sudden happens as you or they drive.
One assessment of "good familiarity" with the line might be if you're never way too wide at any corner apex, or apexing too far before you get to the apex cones . . . and knowing when you're "off" a bit as it's happening whether your error is too early, too wide, or even too late.
One other thing - "winning" at a track day is to be able to drive your car home in the same condition it was in when you drove it to the track (minus some tire tread and brake pad life).
Which has brought me to strongly recommend a full brake fluid flush and replacement with one of the better DOT4 fluids and strong consideration of swapping in a set of at least entry-level track pads. Motul RBF600 is what I use for fluid and is my recommendation to you at this point, and there should be a Carbotech track pad compound that you can at least sort of use in daily driving. Brakes are at least as important as anything you do with respect to limiting engine power because even a NA car can and will run into brake fade in less than a full session at speed.
Norm
Norm Peterson is offline   Reply With Quote
Old 01-02-2015, 01:43 PM   #7
forklord
forklord's Avatar
Drives: 2010 2SS
Great advice...i kinda was trigger happy with the mods last year and realized after a few close calls that i should try road cpurse and not public roads...i should just private sale this thing or part it out....get a z/28...but first maybe ill go on a cool day for one lap at a time and see if its right for me. Thanks guys!
Old 01-02-2015, 03:05 PM   #8
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
good advise from all above. i'll add one more before you spend a bunch of money
take the car out as is and see if you like road racing (you will). for safety's sake, it would be good to upgrade the brake fluid before you go out.
that said, monitor your temps, don't try to be the fastest on the track, learn the line, listen to your instructor and most of all have fun
h018871 is offline   Reply With Quote
Old 01-02-2015, 03:38 PM   #9
forklord
forklord's Avatar
Drives: 2010 2SS
I think ill get an oil cooler and bigger rad before hand cuz theyll be handy for another engine or whatever regardless.
Old 01-02-2015, 04:33 PM   #10
MTCobra
Drives: 2014 ZL1
Norm
Great quote Norm. Couldn't agree more. We all love to outrun our run group but to me it's really become about constant improvement...improving MY lap times with the car I have by improving my driving.
2014 ZL1
MTCobra is offline   Reply With Quote
Old 01-02-2015, 09:25 PM   #11
Synner
Drives: cars
Your first time or two you won't be seeing super high temps since you'll be learning the course and the car. Go to a HPDE where you get an instructor in the car. They will tell you to only drive at 6/10th's so that your focus is on learning the line and not trying to reign in horsepower or worry about losing it. If you get a good one they will be teaching you the entire time as you progress, speed it the last thing to be worrying about so your temps concerns will be minimal starting out.
Old 01-03-2015, 08:44 AM   #12
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
I've done 9 HPDE days. Only mods I have done are suspention & tires. I'm an old crotch rocket rider(I have plenty TRUE unbeliveable stories) and I will tell you the road course WILL intimidate you at first, there is a lot going on, on the track. The Camaro is fast stock! Want to go fast? SEAT TIME! Extra HP WILL slow you down. Do yourself a favor and do a track day or two THEN think about mods. Your perspective will change!
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 01-03-2015, 09:15 AM   #13
forklord
forklord's Avatar
Drives: 2010 2SS
im thinking my best bet is to wait it out and get a 2016/17 1le or equivelant in the future and keep my 2010 for the street . im also thinking, for now, sell the s/c and go with agp turbos and a good boost controller so i can turn it down at the track and still have big power on the street until a dedicated track car is feasable. then if i decide to get more power in my 2010 the supercharger wont hold me back as much. i think that makes the most sense where im sitting right now?
Old 01-03-2015, 11:48 AM   #14
jamestown
jamestown's Avatar
Drives: 2014 1le
To be honest, no. This is what will happen to you. You will go to the track, you will love it. You will keep going with the car you have. Stuff will break. You will realize it costs an insane amount to track even a stock car, let alone a heavily modified one. At which point you will either stop tracking, or only spend money on mods that help reliability from that point forward. Forget your street car power mods, tracking is a whole new addictive level of adrenaline.
jamestown is offline   Reply With Quote
