Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 04-07-2017, 06:18 PM   #71
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Originally Posted by DarkFangz1100 View Post
Best I've gotten so far is a 5.9...If I use my throttle controller to SP9 i usually hit about a 6.3 due to the tires spinning...and wasting time
Yeah, the powers there to do a low 5, I just need to get the launch dialed. Not sure it's possible with these tires and wheels, but I'm gonna give it my best shot. Once I get enough test runs in, I'll think about adding or changing stuff. i.e. CAI, hot cold side pipes, intercooler, downpipe and a tune. Maybe smaller rims and tires if the bug really bites me bad.
2017 1LT RS I4 A8 BLACK ON BLACK
Kindness and compassion #OthersFirst
Michigan1LTRS is offline   Reply With Quote
Old 04-08-2017, 01:48 AM   #72
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
I Average 5.6 best was a 5.3 tire spinning is a frequent issue with the stock tires damn run flats are to hard.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile
Evil-Bee-NH is offline   Reply With Quote
Old 04-10-2017, 06:42 AM   #73
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
5.6 is a solid average for myself also... The runflats do hold the numbers down a bit for sure.
Looking forward to trying this again with more rubber (305's inbound )
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Corner carver is offline   Reply With Quote
Old 04-15-2017, 06:15 PM   #74
vaspen
vaspen's Avatar
Drives: 2017 l4 blue 6speed
Michigan u mean a dead 5 lolol
vaspen is offline   Reply With Quote
Old 04-15-2017, 06:17 PM   #75
Michigan1LTRS
Blessed ❤️
Lol, well, I meant for me. I know you totally killed it.
Old 06-02-2017, 11:04 AM   #76
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
LTG 0-60 times, stock or otherwise
Today. Mods: catless DP, Jacfab big mouth tb and charge pipe, LSD diff swap, and tune (still tweaking on the tune), and I have my ghetto drag wheels on
Jason@JacFab is offline   Reply With Quote
Old 06-13-2017, 04:41 PM   #77
Corner carver
Man that is getting quick I'm still trying to coax out a 5.0 stock... It's really beyond me how guys are getting this...I've got my average down to about 5.4 and can nail 5.3 and 5.2's now with consistency...but a 5.0 stock? Don't know if me or the car has it in it.
With the weather warm again I'm likely out of luck until fall...
I'm hopping to have a racepak gps unit for the 1/2 mile this August for more accurate numbers....then I can finally add another section to my build thread... (i know, i know...don't anyone hold their breaths lol)
Old 06-13-2017, 06:33 PM   #78
Jason@JacFab
Old 06-14-2017, 05:21 AM   #79
Corner carver
Originally Posted by cooper1965 View Post
What RPM are you shifting @ , out of curiosity ? 5.2 is nice @ 2k? ish alt.
Coming out of the hole at 3000rpm and using no lift shift at 6000ish rpm. You can hit 60mph in 2nd with the M6...I've gotten 5.2 with both staying in second and shifting to 3rd (the car noses over so hard after 5k you can make up the same time short shifting 2nd)
Old 08-16-2017, 03:21 PM   #80
Jason@JacFab
Old 08-16-2017, 03:52 PM   #81
Corner carver
Originally Posted by Jason@ View Post
Heck yah! Putting the hurt on those V8's!
Old 08-18-2017, 06:42 AM   #82
KingOmen
KingOmen's Avatar
Drives: 2017 Camaro 2.0T M6 RS sunroof
Mine doesn't have this performance timer... Mine has a regular timer which is really crappyand I find no use for it....
KingOmen is offline   Reply With Quote
Old 08-18-2017, 07:19 AM   #83
Michigan1LTRS
Blessed ❤️
All Camaro's have it. You have to add it in using the menu system. Default setting is off.
Old 08-18-2017, 04:33 PM   #84
attymf
attymf's Avatar
Drives: 2017 SS
SS, A8, Procharger, M&T's and stuff...
attymf is offline   Reply With Quote
