04-24-2024, 07:49 PM | #1 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
Oil pressure after oil vhange
Did anyone else notice that the oil pressure is a bit higher after a fresh oil change?
Here’s mine |
04-24-2024, 09:08 PM | #2 |
Drives: ‘23 ZL1-1LE Join Date: Mar 2023
What was the oil temperature, was it the same in both instances? It’s also possible that the oil was diluted/contaminated with fuel.
04-24-2024, 11:50 PM | #3 |
Drives: 6th Gen LT1 Join Date: Jun 2023
yes a couple of PSI. It's normal
04-25-2024, 04:51 PM | #4 |
Drives: 2018 ZLE Join Date: Feb 2018
Mine after oil change.
04-25-2024, 05:02 PM | #5 |
Colder oil will always be higher so it also depends on ambient temps.
04-26-2024, 01:21 AM | #6 |
ZL1 Driver
Yes, it was about 40psi with initial start. As it warmed up, the idle psi went from 40 to 31 when fully warmed up.
