05-18-2011, 03:58 PM | #1 |
My Addiction
Vert Top Rattle Concerns
Ok so its been about 15 years since I have had a ragtop so needless to say technology of today is nothing like it used to be. That being said, I am wondering if my expectations are too high...... BUTTT.... I have rattle and I am wondering if it is normal.
My ragtop rattles inside the area where the release handle is located. I did not notice this when I first brought her home; it seems to be something that has magnified with vert top usage. And of course, any bumps,etc in the road makes it rattle more. Anyone else out there have this rattle? Is it perfectly normal and am I being overly protective of my girl?
05-18-2011, 04:21 PM | #2 |
Quit being a pu$$y
Sounds like something may be loose in there. I don't think mine rattles, I would take out by the dealer do they can look into it.
05-18-2011, 04:27 PM | #3 |
Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
No rattles on ours.
Fquick.com/NineBall
05-18-2011, 06:42 PM | #4 |
Drives: 2011 2LT RS IOM Convertible Join Date: Dec 2010
No rattles in ours either
05-18-2011, 06:50 PM | #5 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
I've had two CTF convertibles for extended periods. Neither rattled. I'd suggest you take it to your dealer for a look. I can assure you your expectations are NOT too high. You should expect a rattle free Camaro, convertible or not.
05-19-2011, 05:57 AM | #6 |
My Addiction
thought so. Thanks guys(&gals) - guess I will be making a trip to the dealer.
05-19-2011, 01:03 PM | #7 |
Quit being a pu$$y
Wow, the IO interior really pops on a black vert, nice!
05-19-2011, 03:01 PM | #8 |
RIP - Convertible SS
Drives: '13 Mustang Boss 302 - RED Join Date: Apr 2011
Mine picked up a significant rattle yesterday on the way home. Sounds like its coming behind the driver' right, back over the rear seat. Haven't looked around back there yet, but will this afternoon. Only happens when the top is up.
Also, since day 1, my driver's side window squeeks where it meets the weatherstripping on the top. Thought it would go away after the foam "broke in" a little, but it hasn't. |
05-19-2011, 03:47 PM | #9 | |
Drives: 2017 Raptor, 2017 SS Join Date: Feb 2010
Check the "bump stops." there are two, one on either side of the car an it seems that is what provides tension on the convertible frame when it is up (i.e. so it is not pulling directly on the deck lid). I could push down on the vert top near the back and it would be just springy enough to come back and hit the bump stop, causing a rattling. I adjusted it one turn (further down) to add just a bit more tension and mine stopped. you should be able to see them with the vert top in a mid position, looks like a plastic cone on a threaded screw. I am sure as the weather changes significantly those may need to be adjusted to accommodate for the heating and stretching of the top. hope this helps... I can take pictures later if needed. Tim
Saving for: 2019 ZL1 convertible.....
SOLD:2016 2SS Red Hot Convertible with black metallic rally stripes SOLD:2011 Silver Ice Metallic 1SS/RS Convertible. Completed modifications: installed factory HUD, deleted AFM/DOD, Dynatech LT coated headers with high flow cats, Solo Cat back exhaust, CAI inc. intake, Vmax ported TB, SIM quarter flares/splash guards, steering wheel radio controls, PDIM iPod interface in center console, RX catch can, JRE cold air scoop, windshield washer bottle relocation. |
05-19-2011, 04:16 PM | #10 |
Thanks Tim! I'll take a peek at that later and report back.
05-19-2011, 06:48 PM | #11 |
Found the stops....they were tight.
05-19-2011, 07:16 PM | #12 |
the stops were tight on mine too, it was how tight the convertible tops aluminum support bow rested against the bumpers, or rather were pushed against it. I pushed on the bottom area of the top, nearest the trunk, where the bow was and was easliy able to get the top to push away from the top lip of the black trim around the trunk area. To me this said that the little stops were not holding the bow far enough down (and hence tight) and allowing the bow to bounce or vibrate going over bumps as slight changes in the top happened. I adjusted the bumpers down by loseing the nut and just one turn to apply more pressure to the bow when the top was up, preventing it from being able to bounce around. I still have no problem latching the top either.
hope this explains it a little better.
05-22-2011, 01:10 PM | #13 |
My Addiction
So now that my intention is to take my rattle to the dealer for their assessment, it stops rattling. Almost like whatever was loose has snuggled up against something and is sitting snug now.....
figures.....
03-01-2012, 11:39 PM | #14 |
Drives: 2011 RS Convertible Join Date: Feb 2012
Top rattles...
...Our 2011 RS Vert just developed rattles overhead thru out. There is a TSB from the top company and parts had to be ordered. The day we drove off the lot after the repair was done, the rattling is still there!...DOH!!!!, Good job Chevy!
Similar Threads | ||||
convertible top alignment bushing pops out. | Keith.M | Camaro Convertible Forum | 22 | 08-24-2011 03:06 PM |
700 mile Camaro Convertible review... | Drago77 | Camaro Convertible Forum | 87 | 04-22-2011 07:33 AM |
A thought just occured to me, if you had to choose. | Mindz | 5th Gen Camaro SS LS LT General Discussions | 19 | 09-29-2007 06:24 PM |
Coupe, Vert, Hard Top Vert, T-Tops, or Removable Roof Panel? | TAG UR IT | 5th Gen Camaro SS LS LT General Discussions | 42 | 08-02-2007 10:46 AM |
Ford gets 5 top quality awards | KILLER74Z28 | General Automotive + Other Cars Discussion | 5 | 06-13-2007 12:28 AM |
