05-12-2016, 03:31 PM | #1 |
Yee-aay-ee!
Drives: 2015 2SS/RS CV CE Join Date: Nov 2015
Is it supposed to do it?
Several days ago, I had to honk the horn at someone who was about to pull out in front of me. When I pressed it, the radio immediately went to mute mode.
Then a couple of days, I had to honk the horn at someone else who almost backed into my car. I was on a call using Bluetooth at the time & when the horn was pressed, it immediately disconnected the call. I searched the forum, but couldn't find something related to this issue.
05-12-2016, 03:35 PM | #2 |
Drives: 2010 2SS Camaro 6sp. Join Date: Jan 2012
Hmmm never had that happen before. Maybe you were in an area with bad Reception?
05-12-2016, 03:44 PM | #3 |
Yee-aay-ee!
If it was a coincidence, what about the muting though?
05-12-2016, 04:22 PM | #4 |
Hmmm did the radio turn off at all? Not mute but just shut off and then back on.
05-12-2016, 04:26 PM | #5 |
go out and try it again in your driveway
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M 11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M 10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M 10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS) Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM |
05-12-2016, 04:44 PM | #6 | |
Yee-aay-ee!
Actually, when I get out of work I'm gonna look for an asshole driver at which I can honk.
05-12-2016, 04:47 PM | #7 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
Just a thought, but did you hit the mute button when going for the horn? It is the same button as the hang up button I believe. Just a thought.....
05-12-2016, 04:51 PM | #8 |
Yee-aay-ee!
Good point. I'm 99% sure I didn't, but we'll see what happens when I attempt to recreate the issue today.
05-12-2016, 04:57 PM | #9 |
Drives: 2011 1LT Join Date: Mar 2012
A few years ago, I was curious to know if the air horn on my big rig could exhaust all of its air--- while the rig was running--- if I were to just keeping it going for an extended period of time. I did it running across the high plains of northern Nevada late one night, far, far, far from any human beings who might get bugged at such a stunt. 20 minutes of air horn could get a trucker shot in some places.
I recommend that you go out of town to try it, if you are going to give it a solid test. You can probably get away with a couple of short honks, but in order to go all MythBuster on this question, you should head for BFE. (In case you were on the edge of your seat: Nope, the rig never came close to depleting the air horn pressure... that thing would still be going all the way through Donner Pass and into Sac if I let it...) |
05-12-2016, 05:09 PM | #10 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
Same thing happened to me and also to another member here, although we both also slammed on our brakes at the same time, so one of those two (if not both) caused the radio to mute. I think that's a security feature; if you have to use your horn and/or brakes, you don't need the distraction of music playing, so it mutes. I can't see the use in disconnecting a phone call though unless that's unavoidable because of the way it's wired.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
05-12-2016, 05:20 PM | #11 | |
Yee-aay-ee!
05-12-2016, 05:36 PM | #12 | |
corner barstool sitter
Been there a couple of times, sort of, in my wife's Subie (instead of the radio going silent, a disembodied voice started speaking at me about something I couldn't have cared less about then or care at all about now). Norm
05-13-2016, 07:33 AM | #13 |
Drives: 2013 Camaro 2SS RS 1LE Join Date: Jun 2013
It's probably tired from you always honking at everyone. Have you started yelling at kids yet to get off your grass? :-) Hope you figure it out soon.
05-16-2016, 03:06 PM | #14 | |
Drives: SRT Yugo GT Super Sport with Manual Join Date: Mar 2012
