10-15-2021, 02:32 PM | #1 |
Drives: 2022 Chevrolet Camaro Join Date: Oct 2021
New Convertible Road Noise
Hello guys,
I just purchased a brand new 2022 SS convertible a couple days ago. This is my first modern convertible, but I was wondering to those who have a convertible is there a lot of road noise in yours? Because when I drive mine, the road noise is a bit loud. I knew the convertible would be louder than the coupe, but I wasn’t expecting it to be this loud. I live in Texas, so most of the roads here are concrete so they are louder than the asphalt roads, so I was wondering if this is more of a tire issue or if this is normal? I haven’t really played around with the windows because they were recently tinted. Let me know based on your experiences. Thanks |
10-15-2021, 03:02 PM | #2 |
i have a 2015 RS coupe.depending on what road im on and speed im driving it can get loud enough where people can hear it over the phone.usually concrete and 70 mph up is the bad spot.
10-15-2021, 03:07 PM | #3 |
Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
Have you had a car with run flat tires before this? They are quite a bit louder than equivalent "normal" tires and might be part of what you're hearing - has to do with the stiffer sidewall construction on the run flats.
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
10-15-2021, 03:15 PM | #4 |
Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
Ii had a Gen 5 2SS and a Gen 6 2SS and the Gen 6 is MUCH quieter. You'll find the stock tires on your2SS are quiet on good/new asphalt. That narrows it down to loud roads or wind noise from a window or something. For the 'vert, id highly recommend the windscreen for when the top is down. Cuts down on wind noise and makes it easy to talk, also keeps the heat or AC in the front seat. If a call comes through with the top down, just put the windows up and you'll be able to talk. Welcome to the forum, and there is a convertible section you may want to peruse.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
10-15-2021, 04:23 PM | #5 |
I actually never tried the car with the top down, I don’t mind a bit of wind noise, but I believe like you guys said it would most likely be the tires that are making most of the noise. And yes these are my first run flats.
10-15-2021, 07:13 PM | #6 |
JKSully is right on the money, when you ditch the runflats, you'll lean back and enjoy the ride. My insurance has tow coverage, that's my plan if I get a flat.
10-15-2021, 07:44 PM | #7 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
I didn’t think the runflats were that noisy…a rougher ride, of course. I guess it all comes down to what you’re used to.
I know for certain if there’s a decent amount of wind noise / turbulence,even with the top up. |
10-15-2021, 07:57 PM | #8 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
I have had both and the coupe is pretty loud as well epically on certain pavement. The vert same. There is a couple of cardboard type pieces that goes on the bottom of the coupe that i put on my vert. I think it helped a lot. IMO its as quite as the coupe was. The only thing thats different is sound from behind that comes through the top say a diesel truck behind me at a relight is louder than the coupe. Search my post in the vert form for more info and I think I posted part numbers
10-16-2021, 05:39 AM | #9 |
Its not just runflats that can be noisy. I have a set of Michelin Pilot Super Sports on my C6 Grand Sport and while they were quiet when they were new, they now are a lot louder with a bit of miles on them.
10-16-2021, 01:13 PM | #10 | |
Thanks! |
10-16-2021, 05:29 PM | #11 | |
Hot Camaro
10-16-2021, 07:01 PM | #12 | |
10-16-2021, 08:59 PM | #13 |
Drives: 1931 Ford 1941&1963 Chevy. 2020 LT1 Join Date: Aug 2020
I must be old and going death. When I drove my new 2020 LT1 vert 450 miles home I was amazed of how quiet it was for being a convertible . But then again most of my old cars have cozy wings on them.
10-17-2021, 07:01 PM | #14 |
Hot Camaro
I have the OEM one. It folds down to fit in the trunk if you want.
