04-16-2017, 02:19 PM | #1 |
Drives: 2011 Camaro 2SS Manual Join Date: Mar 2015
What Is The Best High Torque Mini Starter???
I need to replace my OEM starter getting heat soaked on hot starts. I heard those high torque mini starters are the best at resisting heat so what is the BEST BRAND to get? Part number would be very helpful also.
THANK YOU Last edited by CamaroNoob; 04-16-2017 at 02:34 PM. |
04-16-2017, 05:39 PM | #2 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
While working at summit racing, I know Powernaster is a very well know quality brand. Don't know part numbers off hand but they are very reliable.
04-17-2017, 12:27 PM | #3 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Yea I'm having the same problem. Anyone have the part number for powermaster??
Pity a man in familiar places, who yet feels like a stranger.
04-17-2017, 12:45 PM | #4 |
Drives: 2010 Camaro SS/RS - IOM - LS3 Join Date: Aug 2015
wow...that was a problem with the 2nd gens. Hard to believe it hasnt been addressed yet.
04-17-2017, 01:26 PM | #5 | |
Drives: 2014 2SS/RS Join Date: Dec 2014
Factory has a heat shield in between at the yellow arrow in very bottom of picture below.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
04-17-2017, 04:16 PM | #6 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
On my BBC drag car the only starter I have found over the years that survives is the Powermaster Ultra Torque. I think it's a 4.4 to 1 gear reduction. I've broke a few Tiltons, the Powermaster seems indestructible. Mine came with a dyno sheet too. You know you've got a mack daddy starter when it's been factory dynod. Mine turned 3.7 hp. They make several levels, the Ultra Tq series is the really good one.
Really good customer service too. I broke the pinion gear once, my mistake the starter timing retard wire had come out of the MSD box. So it tried to start at 42 deg advance. Broke the pinion gear. I sent it to Powermaster, they fixed it up for next to nothing and redyno'd it. |
04-17-2017, 04:17 PM | #7 |
What's the part number for it? And is it smaller than OEM cause I could barely get the OEM started out last time.
04-18-2017, 07:42 PM | #8 |
Anybody have z experience??
04-18-2017, 07:49 PM | #9 |
Drives: cars Join Date: May 2011
Starter selection has nothing to do with thermal management.
04-18-2017, 10:25 PM | #10 |
04-19-2017, 09:14 AM | #11 |
Drives: 2012 RS/2SS, 69 ProStreet Camaro Join Date: Oct 2011
A less expensive alternative is to just cover you stock starter with a heat wrap like DEI. In most cases on a street car it's all you'd need. Another option is to use header wrap on the exhaust. Both are cheaper and easier to install than replacing the starter. See links below.
https://www.summitracing.com/search?...starter%20heat https://www.summitracing.com/search?...=header%20wrap .
04-19-2017, 09:17 AM | #12 |
My wrapped my starter in heat blanket and it didn't do nothing. But it was after it started showing symptoms
04-19-2017, 10:28 AM | #13 |
A couple of the Powermaster LS starters are Part # 9009 and 9509. I think 9509 will be the higher tq.
Best to call their tech line and see what they recommend. They've always been very helpful when I call, and can tell you exactly which will work best for your application. 630-957-4019. |
04-19-2017, 11:24 AM | #14 |
