dave@hennessey
Old 05-05-2022, 10:20 PM   #1
Nz2ssrs
Drives: 2012 2ssrs giovanna edition (japan)
L99 sport mode not working
Hi Guys,
My 2011 2ss had never really driven any differently in sports mode until the other day.
I slowed down for a corner then accelerated out of it hard and then backed off for the next corner. When I backed off it held the revs high and when I was braking for the corner it raved up and power shifted down into the next corner. It was actually working how I expected sports to work. Then coming back through the same corners again later that day if did the exact same thing. Since then I can not get it to work in sports mode the same way? What am I missing?
It shifts into sports and shows “s” on the dash but drives no different to “d”
What are the requirements for sports mode to work fully?
Nz2ssrs is offline   Reply With Quote
Old 05-06-2022, 07:06 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
I've only used Sport mode a few times (I always use the tap shifts) but from what I remember you just need to drive the car hard - driving "normally" won't be much different than D, but stomping on the throttle and brake pedals will let the computer know you want to go fast.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 05-06-2022, 07:47 AM   #3
Nz2ssrs
Yea I tried stomping to the floor, tried full throttle to 60mph and backing off, tried full throttle from 0-40mph, tried 3/4 throttle and 1/2 throttle in the same tests and nothing…. As soon as you take your foot off the gas the revs drop to just over 1000
I’m thinking there’s something else going on not allowing sport mode like the engine temp isn’t getting hot enough? The analogue gauge sits at 1/3 at running temp which is weird as all my cars normally sit at 1/2 way point.
On the digital gauge it’s 189 deg f normal running temp.
Old 05-06-2022, 03:44 PM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
While driving in M (Manual Mode),
if Tap Shift has not been activated,
the transmission determines when
the vehicle is being driven in a
competitive manner and will select
and hold the transmission in lower
gears and have more noticeable
upshifts for sportier vehicle
performance.
My 14 SS Sedan does the same thing, I've only been able to activate it going around corners. You have to hit the gas hard going around the corner.
SlingShot is offline   Reply With Quote
Old 05-06-2022, 06:02 PM   #5
Nz2ssrs
performance.
Yea this makes sense as it happened straight out of a corner, maybe there’s a sensor that picks up g force to initiate it?
Old 05-06-2022, 07:47 PM   #6
gtstorey
It could use the yaw sensor with the wheel speed sensors.
Old 05-06-2022, 08:52 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I have found that it can be a bit too aggressive on the downshifts sometimes. It's funny when it happens and you aren't expecting it. I rarely ever use it though, as I just use the paddles 100% of the time.
I wonder how well it works for road track usage - whether the algorithm is smart enough to keep it from actually becoming a hinderance. My god, I really wish the tech in the new 10 speed autos had matured sooner so we could have gotten it. The 6L80e is a good, solid trans that can take a ton of abuse, but smart and quick it is not.
InFiD3ViL is offline   Reply With Quote
Old 05-06-2022, 09:21 PM   #8
SlingShot
SlingShot's Avatar
My Sedan does the same thing on downshifts and upshifts, especially after getting an aggressive trans tune. The first time it happened, I got a message that popped up that said "Performance Shifting Active" and I said cool...
Old 05-06-2022, 11:23 PM   #9
Nz2ssrs
Where did you get the message of performance shifting active ?
I just can’t get it to go into this mode and the one time I did I didn’t see any message
Old 05-06-2022, 11:25 PM   #10
Nz2ssrs
What are you doing to get it to come on? Does it just drive normally in sport until you do something ? I screwed the shit out of it and couldn’t get it to kick in.
Old 05-07-2022, 11:09 AM   #11
SlingShot
SlingShot's Avatar
That wasn't on my Camaro, that was on my SS Sedan. It may be a Holden thing...
