07-20-2017, 04:32 PM | #1 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Problem with TPMS
Every time it gets hot out 90+ or I do some spirited mountian driving my right rear TPMS goes out. the tires have been rotated and the sensor has even been changed. The problem is always the right rear.
Does each wheel have a separate reciever? I thought it was a centralized antenna using the keyless entry antenna. Anyone else experience this issue?
The Bird is the word! |
07-24-2017, 03:34 PM | #2 |
Drives: 13 ZL1 Join Date: Jun 2017
The battery is probably going low in that sensor. I had one in my CTSV that did the same thing. Just replace it.
07-25-2017, 09:09 AM | #3 | |
Now the error is random, sometimes right rear sometimes left rear... I know unless the dealer can duplicate it they won't do anything. Guess I will just wait till the whole system crashes.
07-25-2017, 09:35 AM | #4 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
I hope you replaced them with OEM TPMS. I've been told of complaints of aftermarket ones.
07-25-2017, 09:40 AM | #5 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I wonder if the issue is with that wheel's hub instead of the TPMS?
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
07-25-2017, 09:49 AM | #6 |
Also moved it to a different location, still has an issue with right rear and now left rear. Random error. That sensor is now on the right front.
07-25-2017, 09:51 AM | #7 |
Doubt it...
08-13-2017, 11:39 PM | #8 |
2013 ZL1
Drives: 2013 ZL1 m6 Join Date: Oct 2010
Ever figure this out? I have the same issue, anytime the pressure drops to around 32psi the tpms freaks out and says service system. I took it in and was told it was normal. I still have the issue.
08-14-2017, 09:57 AM | #9 |
That's not normal. The one time I did have a nail in a tire TPM came on at about 23-25 tire pressure... I normally go with 34 TP all around.
08-14-2017, 11:08 AM | #10 |
The error has moved to the left front the last several times it came on, but it is so intermittent that until it fails constantly the dealer won't be able to fix it.
08-15-2017, 05:10 PM | #11 |
Drives: 2013 SS Convertible, ThumperII Join Date: Nov 2016
Mine doesn't come on that often but it does and its random. 2 or 3 cycles of the key and its gone.
08-15-2017, 06:28 PM | #12 | |
When it fails the effected tire just shows a -- the rest read normally.
08-15-2017, 06:45 PM | #13 |
mine was doing this.dealer finally had to lengthen the wires from the door lovks and get them away from the heater motor.there should be a thread on it in here somewhere,as it took 3 trips to the dealer to fix.
08-15-2017, 06:46 PM | #14 | |
Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
Tpms
