Vararam
Old 07-27-2017, 10:12 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
1LE cradle bushings
Does a 1LE have different cradle bushings than a regular SS?
zz430camaro is offline   Reply With Quote
Old 07-28-2017, 04:14 AM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
Yes, the are much firmer but you can get stiffer ones. When I had the 1LE track pack installed on my car it really help cut down on wheel hop.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-28-2017, 08:23 AM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Get solids from one of the vendors you won't be disappointed!!
Orange Krush II
Old 07-28-2017, 08:57 AM   #4
zz430camaro
Drives: 2015 1LE
I have a 1LE and wanted to upgrade the subframe bushings and was trying to decide on poly or solid. Sounds like most people recommend solid. Even though these dont transmit much NVH I was wondering how it will get with aftermarket trailing arms with poly bushings.
Old 07-28-2017, 10:44 AM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I would get Solids!
However, remember if you replace your Cradle or Diff Bushings, there is no way to go back without buying a New Cradle
Old 07-28-2017, 11:02 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You shouldn't see any NVH till you do diff Bushings and only minor on arms.
Orange Krush II
Old 07-28-2017, 11:19 AM   #7
zz430camaro
Drives: 2015 1LE
Solid it is!
