07-14-2017, 03:14 PM | #1 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
1LE with 47k
I'm doing 1.25" BMR drop springs with JP billet radius bushings plus I did new front struts about 6-8000 miles ago and just got the rears ones to go on as well !! Anybody recommend anything else I should do well I'm at it ?? ?? Thanks
07-14-2017, 04:05 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Aluminum subframe bushings and if you decide to do those, add Z/28 upper control arms bushings while you're at it
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
07-14-2017, 04:15 PM | #3 |
Hmmmm ok ok thanks
07-14-2017, 04:28 PM | #4 |
'It's an experiment'
JusticePete would be an excellent resource -- depending on what you intend to do with the car (track it or not). I've spoken with Pete several times and I really value his opinion. You were at the mileage to replace the Struts and Shocks for sure.
I agree with the solid subframe bushings -- I have them and I'm glad I did those. I'd also flush the brake fluid at that mileage -- it you track it or not, go with a dot 4 fluid. I had Motul 600, and recently flushed again after 2 years with Castrol SRF -- more expensive, but for tracking a car, nothing better. If you do go dot 4, get one of these: GM part number 924578250 Dot 4 cap Then get this as the seal in this cap is a bit thin: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
07-14-2017, 05:24 PM | #5 |
Plus one on the UCAs there a bit of a job but along with cradle bushings and the Z bushings it improves acceleration. The rubber cradle bushing have to fill the voids as your accelerate causing a ever so slight delay.
Orange Krush II
07-15-2017, 08:09 AM | #6 |
Pete will probably reply after the Camaro Fest. All the vendors are there now and are busy and drinking.
07-15-2017, 08:46 AM | #7 |
I don't track the car !! Just spirited street driving..
07-18-2017, 06:46 AM | #8 |
Nobody else ?
07-18-2017, 07:30 AM | #9 |
Drives: 2015 2SS 1LE Join Date: Dec 2011
This is the aggressive street driving build that Pete recommended for me and I am having him do the work in August. Not to speak for Pete but thought I would share:
JPSS Black Caster Locks Camaro 2010 - 2015 Billet Radius Arm Bushing JPSS Camaro 2010 - 2015 5th Gen 32mm Rear Sway Bar Z/28 Rear Upper Outer Rear Control Arm Bushing Set BILSTEIN B6 5th Gen Camaro 2010 -2015 DSE 1.5" Lowering Springs Tight Spec Alignment |
07-18-2017, 08:56 AM | #10 |
Ok thanks. I do have a 1Le so not sure if I need all that ?!?!?!
07-18-2017, 01:14 PM | #11 |
07-19-2017, 06:00 PM | #12 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
I have done everything Tunamanz is doing, except I went with BMR -1.25's.
Are you doing the work yourself? If so, you might as well do these last three things, just makes the 1le a Z28-lite. JPSS Caster Locks and Z28 RUCA bushings- You will have most of the suspension loosened/removed and getting an alignment anyways. Extra $230? JPSS Rear Sway Bar- Makes the car rotate so much better; turn, punch it and hold on because it is going where you point it. Just makes the car gently slide around the corner. If money is an issue, do the first two and the rear sway down the road. You might also want to sell your 1le struts for and flip that money into buying the B6's. That way they will only cost you $400 or so??? That is what I did. Take some time and plan it out and do it once the right way. |
07-19-2017, 08:07 PM | #13 |
Thanks bud
07-20-2017, 10:02 AM | #14 |
Drives: Camaro Justice Join Date: Jun 2007
You are in good hands with these guys.
