05-04-2017, 10:40 PM | #1 |
Drives: 2015 Camaro LS Join Date: Jan 2017
ZL1 Replica Wheels Question
The top picture is my car , The others is what I want My car to look like.
I just got out of highschool so I dont know much about stuff like this , I do have a V6 Camaro LS. Does any one know Which Size ZL1 Wheel(s) I need to get to achieve this look? |
05-05-2017, 05:33 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Fronts are 20x10", +23 mm offset; rears are 20x11", +43 mm offset. If you're buying replicas they will be available in these sizes/offsets. You can also consider 20x10" with +35 mm offset for a square setup and this way you can rotate tires on all four corners, if you like to be able to.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
05-05-2017, 08:15 AM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-05-2017, 03:20 PM | #4 | |
05-05-2017, 03:52 PM | #5 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
check out Factory Reproductions to see their options. With gloss, there is more work involved to keep them glossy... matte is for the lazy guy
My eyes are terrible but I think the first black car might have actual ZL1s which will have the word "Camaro" stamped on the outside lip. good luck. joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
05-05-2017, 09:53 PM | #6 |
All personal taste, but generally I prefer glossy over flat - just looks nicer, flashier, and I like shiny stuff. I think gloss would go better with a factory-painted black car; likewise flat black wheels would go better if the car was flat black too, but again that's just me.
05-05-2017, 10:00 PM | #7 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
I went 20x9 up front and 20x10 on the rears
Factory reproduction gloss black Sent from my iPad using Tapatalk
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
05-08-2017, 10:25 PM | #8 |
War Horse Pilot
20X10 and 20X11 rears. No rubbing and lowered 1" overall.
05-09-2017, 11:01 AM | #9 |
EbonyCamaro
Warhorse +23 or +35 on the front offset? I'm lowered 1" also and have been thinking of upgrading from stock ss rims.
05-09-2017, 12:00 PM | #10 |
I'm 20X10 all around and lowered 1"
05-09-2017, 01:27 PM | #11 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
Nice. I run the same setup with a +23 offset all around. Lowered 1". I'm running 285-35-20's all around. Rubbed up front when I had 275-40-20's autocrossing.
05-09-2017, 02:37 PM | #12 |
drinks virgil's
Drives: 2010 2SS M6 Join Date: Feb 2014
Same as above. 1" lowered on BMR springs, 20x10 all the way around with a +23 offset with 285/35's.
In the three pics you posted, the second one down probably has the LG ZR28's if they're not factory wheels. There's a slight difference between the LG's and the Factory Reproduction style (what's in the 3rd pic) where the spoke meets the outer portion of the wheel.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared |
05-09-2017, 02:58 PM | #13 |
GPI Sales Consultant
I run 20x9 with a 275/40/20 on all four corners - the ability to rotate is wonderful, and the additional rubber up front reduces some of the understeer bias the car has in it.
Got a question about a GPI product? Feel free to shoot me a message! |
05-09-2017, 03:12 PM | #14 |
War Horse Pilot
23 I believe. Stock ZL1 offset front and rear. 1" hotchkiss drop.
