TireRack
Old 06-07-2021, 09:09 PM   #1
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Solid cradle bushings half way in
So I followed the instructions for removing the old ones and mission accomplished. But now when it comes to the install I’m stuck at half way.
I had the new bushings in the freezer.
I think my problem might be I half assed it at cleaning the holes out. I got a wire brush drill wheel for when I do the other side.
So now that I’m half in. Do you think I can just muscle them in by tightening the bolt or should I press them back out and clean the hole better?
Open to suggestions
Lnch Mny is offline   Reply With Quote
Old 06-08-2021, 05:39 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
I would only "force" them in if they're almost all the way in, like a quarter inch from seating or so, and I'd use a jack to do it instead of the bolt so that you won't possibly strip the threads.
I'd pull those back out, make sure the hole is clean (put bushings back in freezer while doing this) and then make sure the bushings go in perfectly straight. When I cleaned the holes I made sure the plastic residue was still warm and used a long knife to scrape.
When I did mine I got them in as far in as I could by hand then used a rubber mallet to bash them in as evenly as possible. One or two didn't go all the way in but were ~quarter inch off, so using the mallet I got them sitting as evenly as possible then pushed them in with a jack.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 06-08-2021, 06:31 AM   #3
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
What he said ^^^
larry_g is offline   Reply With Quote
Old 06-08-2021, 07:47 AM   #4
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
Wire brush all of the crap out of the holes. Lube up all of the parts, and the holes. Install the Top Bushings first, then the Bottom's, then the Steel Inserts. I flipped the tool around as necessary and did this in steps. Note – it is very unlikely that you can use the Vehicle’s weight or Cradle Bolts to seat the Rear Bushings, it will strip them.
hesster is offline   Reply With Quote
Old 06-08-2021, 10:53 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I used a long 3/4" bolt, washers and the steel insert. Like Hester said, I put tops in first. The holes were pretty clean and they pulled right in with an old impact I use for situation requiring less than 100lbft.
Old 06-09-2021, 09:04 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I would pull them back out. When we did mine after, after we got the old ones out we used a wire brush and cleaned the crap out of the inner holes of the cradle real good, then before we installed the solids we put a thin film of oil on BOTH the bushings AND the inner mount holes and they just slipped right in, no forcing. Als make sure they go in straight because if the get crooked a bit it will give you problems to get them straight again. Take your time and go slow and you won't have any problems. Good luck.
Old 06-09-2021, 08:51 PM   #7
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Thanks guys! Some good advice here. I’ll dive back in this weekend!
Old 06-10-2021, 07:15 AM   #8
fz4k98
Drives: 2013 1ss
I ran into this with the poly bushings. The problem I found was the frame hole is not perfectly round but the bushings are. I cleaned, lubed the hole,froze the bushing but still did not work. I ended up sanding down the bushing to get it in.
It stiil needs to be a tight (compression) fit for best results.
fz4k98 is offline   Reply With Quote
Old 06-10-2021, 12:04 PM   #9
joshnmn
2&THEHIT
joshnmn's Avatar
The aluminum ones are a beotch to get in. Definitely don’t muscle it- you’ll just make things worse. The front ones are easy, the big back ones aren’t. Gotta make sure it’s clean. That burnt plastic residue is the truth.
Old 06-10-2021, 03:31 PM   #10
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
I used a rotary hand grinder with a flapper wheel to clean up the old residue in the cradle , worked great!
Pkeen is offline   Reply With Quote
Old 06-17-2021, 02:11 PM   #11
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Pull it back out for sure. I warmed the metal surface as mine cooled down and used a wire brush on the end of a drill to clean mine. Bushings are tight, but they should go in.
gunchamp is offline   Reply With Quote
Old 06-20-2021, 12:05 PM   #12
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
The adventure continues! So of course the bushing are in there halfway. I got a hemonic balancer pulley and it’s working beautifully. So well in fact it’s pushing the jack down or heck maybe lifting the car. Either it’s creating a gap vs pulling the bushing out. So I’m thinking heat the cradle? Or just crank on the balancer more? Really striking out here.
Old 06-20-2021, 12:06 PM   #13
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Forgot. Here is the picture for fun!
Old 06-20-2021, 08:06 PM   #14
fz4k98
Drives: 2013 1ss
i have had luck in the past with stuck parts by applying the pressure to pull it and then tap around the side of the part lightly with a hammer. The harmonic of the tapping caused the part to jump a little. Then reapply the pressure and repeat.
