09-06-2022, 09:20 PM | #29 | |
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
Aeroforce gauges can do this, fans and running intercooler pump. You can run it with the car off but I wouldn't run it longer than 10 mins as it will probably draw alot from the battery. |
09-06-2022, 09:56 PM | #30 | |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
Between running the Aeroforce gauge and running the fan you would draw quite a bit of amperage and drain the battery down something decent though, so that's your only warning SOCAL.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
05-07-2023, 08:41 PM | #31 |
Having FUN in the SUN...
Well, I finally made time to test the "fan after shut off" feature in HPT... and it does work perfect! Gonna play around and test for a while, so far have it set to run for 5 minutes at 25% after shut down, to help prevent heat soak. So cool that GM has that feature!
05-07-2023, 09:53 PM | #32 | |
Drives: ‘23 ZL1-1LE Join Date: Mar 2023
05-07-2023, 11:20 PM | #33 |
Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
So it is probably not that much actually....5 minutes of runtime is 1/12 of an hour....so even if he was drawing 12 amps for that period of time he'd only discharge 1 Ah of capacity of the battery...with a 60 Ah plus battery that's really nothing...
05-22-2023, 09:28 AM | #34 |
Drives: '14 ZL1, Duramax H2 Join Date: Apr 2012
I use this Aeroforce feature all the time at the track. Along with adding ice to my IC reservoir I can quickly cool down the IAT2 and MAT temps running the IC pump and fans. Without this function my MAT temp would never come down. So easy to use compared to a laptop. Be sure to monitor primarily MAT (sometimes called IAT3) as that is what the ECM uses to pull timing due to excessive temps. I believe 130 deg F is where it starts pulling timing, chime in if I'm off on this number.
05-22-2023, 03:41 PM | #35 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
I have always left my hood open for a few hours after coming home just for some of that reason.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
05-22-2023, 09:09 PM | #36 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
During warm and hot periods I pull into my garage, open the hood, and blow an industrial fan into the engine bay for an hour or two, depending on how hot it is. I started doing this mainly to get the heat out as quickly as possible to keep the heat out of my already hot garage (it’s SW facing). But it has the added benefit of keeping the components much cooler under hood.
Back in the day in my 1995 Trans Am I replaced the mechanical water pump with a Mezeire electric and added a fan switch so I could run the fans in auto, low, or high. Turning the pump on and the fans on high would cool the engine down in a hurry. Much better than just turning the fans on since the coolant was also circulating. Would be cool to do that with the HX pump on the ZL1.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
05-28-2023, 10:36 PM | #37 |
Drives: 2017 ZL1 Join Date: Aug 2020
So how do u use the aero force gauge to do this?
