Vararam
Old 09-05-2018, 08:07 PM   #1
Prplcat
Drives: 2010 Camaro RS
2010 Camaro timing chain starting
So my 2010 Camaro just started P008 and P009 codes showing the need for a timing chain. At 125,000 miles. I have a couple questions.
1. I was quoted 1,600 out of my pocket for breakdown of the engine to see if my Waranty company ( Endurance) will cover the Timing chain repair. Does this sound right to you guys? Timing chain is listed in my Waranty book as covered but I was told they will probably challenge the repair. Does 1600 for just the breakdown sound right?
2. I'm getting a p0017 code with the P008 and P009. Does this code usually set because the chain has the timing just off, or is there really an issue with the crank sensor that will requir the engine to be pulled?
Prplcat is offline   Reply With Quote
Old 09-05-2018, 08:56 PM   #2
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
For $1,600 I'd buy a cam kit with a new timing chain and do it myself.
Add timing chain set: https://www.texas-speed.com/p-249-te...l92lsal76.aspx
I selected:
TSP Stage 4 "F-35" N/A LS3 235/248, .649/.615, 111 LSA Camshaft (25-TSP235248-111)
3-Bolt Cam Core(-3B)
Standard LSA Listed
7.400"
TSP .660" Dual Spring Kit w/ Integrated One-Piece Seat & Seal, Titanium Retainers, PAC Springs #199-ISSPACPOL660SpringKit
Rollmaster 3-Bolt 4x Double-Row Timing Set (11-CS1195) & ARP Bolt Kit (46-134-1003)
GM High Performance Oil Pump (28-12678151)
Include Crank Bolt/Gasket Kit w/ ARP Bolt #28-CamGskKitARP (OUT OF STOCK)
Do Not Include Shirt
Include Comp 4-7702-1
Base: $659.99
Configured: $944.92
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 09-06-2018, 07:14 PM   #3
JJPlace1
JJPlace1's Avatar
Drives: 2010 2LT Victory Red
I think he has the V6 ?
Previous Vehicles
1970 Impala 2D 350/300
1972 Buick GS 350
1967 Pontiac Firebird 326
1969 Chevelle SS 396/375 I really miss this one
1966 Chevelle SS 396/350
1978 Plymouth Fury 440
1982 VW Scirocco ( Got married )
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
JJPlace1 is offline   Reply With Quote
Old 09-07-2018, 04:15 AM   #4
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
I selected:
That package aint gonna work on a V6......
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Old 09-07-2018, 07:38 PM   #5
Prplcat
Yes it's an LLT V6. Is it normal for the P0017 to pop up with P008 and P009? I don't want to go through the whole timing chain replacement only to find the pressed on crank sensor is bad.
Old 01-28-2019, 01:20 PM   #6
Moser28
Drives: 2010 LT2 RS Coupe
I did not get the P0017 code when my chains started acting up. Just P007. At 105k.
Moser28 is offline   Reply With Quote
Old 02-03-2019, 06:48 AM   #7
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
Left bank , and right bank timing chains. The ECU ( computer ) is checking the time , and position, the gears , controlled by the chains, compared with each other.
Tear down to check it ? They are stretched.
PieNsky is offline   Reply With Quote
Old 02-03-2019, 10:55 AM   #8
cawengr
Drives: Classy
There is a GM document https://f01.justanswer.com/cameronte...6c2_116800.pdf
Apparently the reluctor for the crankshaft sensor has the possibility of moving and throwing those codes.
cawengr is offline   Reply With Quote
