Old 03-25-2013, 09:20 AM   #1
M109pilot
Drives: 2010 Camaro 2SS RS
Nitrogen isn't free?
Called my local Chevy dealer this morning and they want 30 dollars to refill my tires! Is this crazy?
Jason
M109pilot is offline   Reply With Quote
Old 03-25-2013, 09:23 AM   #2
jd10013
Drives: 2012 camaro
considering about 70% of the air your breathing is nitrogen, yes, I'd say it's crazy and a waste of money. personally, I can live with putting a pound or five of air in my tires every 12-18 months, if that. I take my car to get the oil changed (not a DIY'er) and they check the tires anyways.
jd10013 is offline   Reply With Quote
Old 03-25-2013, 09:27 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Use regular air, it's perfectly fine.
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 03-25-2013, 09:44 AM   #4
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
If it was factory filled they gave you a code to give you refills.
if not. then yeh you gotta pay.
and yes it does improve the ride especially on 21s and 22s
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 03-25-2013, 09:45 AM   #5
1966goat
Drives: 2001 Trans Am WS6, 1966 GTO
Send a message via AIM to 1966goat
Improve the ride?
1966goat is offline   Reply With Quote
Old 03-25-2013, 09:48 AM   #6
DuskSS
DuskSS's Avatar
Well not really it stabilizes the pressure changes which makes for a better ride as your pressures fluctuate less.
530/520 SAE
Old 03-25-2013, 09:55 AM   #7
dwinva
dwinva's Avatar
Drives: 13 2SS/RSvert,CRT,dual-mode exhaust
Oh boy, here we go again. Nitrogen does NOT improve the ride of a car in any way. It doesn't matter what tire/wheel size your using. Using pure nitrogen does do two things. One it will reduce the oxidation/breakdown of the inside of your tires by not have oxygen in the tires (really very little oxygen...no one mounts tires in a vacuum). Given the technology in tires today, this really isn't too much of an issue (changes in vulcanized rubber technology, etc). Also, if you think back to your high school chemistry classes, you may remember that nitrogen molecules are larger than oxygen molecules. This means a tire filled with pure nitrogen will loss pressure much more slowly than a tire filled with normal air. Another thing to remember, as stated in a previous post, the air we breathe is mostly nitrogen (about 78%).
Hope this helps.
dwinva is offline   Reply With Quote
Old 03-25-2013, 09:57 AM   #8
mr02Z/28
Drives: 2002 Z/28,1968 Chevelle convert.
My Big Wheel improves ride quality !!!!!!
mr02Z/28 is offline   Reply With Quote
Old 03-25-2013, 09:58 AM   #9
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
One of the best things I ever bought was an air compressor. My tire pressure on all 3 of my vehicles are always at the correct psi. Regular Air
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 03-25-2013, 09:59 AM   #10
Warpaint69
Drives: 2013 VR 2SS RS
Outside of racing applications, its not a need in a daily driver IMO.
Warpaint69 is offline   Reply With Quote
Old 03-25-2013, 10:06 AM   #11
Frank in MD
Raining Blood
Frank in MD's Avatar
Drives: 2014 SS Performance Sedan
Jason
So if I understand you correctly, you would like your dealer to give you free maintenance? I'm not being a smart-ass, I'm asking a serious question. Do you really expect to get free nitrogen top-offs from your dealer when selling it is part of what they make money on? It really doesn't cost the dealer much at all but that isn't the point. The point is if you see the value of nitrogen you will pay to get it. If you don't see any value then tell them to put air in it, as there should be no charge for that. After all oil doesn't cost the dealer much either, but if you expect to get free oil from the dealer.... well, you get it, right?
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured
Frank in MD is offline   Reply With Quote
Old 03-25-2013, 10:11 AM   #12
Spektrum
Spektrum's Avatar
Drives: 2013 2SS 1LE
Nitrogen systems aren't free, especially those that are plumbed throughout the repair shop vs. a small roll around. It cost $10,000 to put it in our 5 bay shop, so you should expect to be charged for it. A lot of shops are offering free top-offs for a year or two with the purchase.
Spektrum is offline   Reply With Quote
Old 03-25-2013, 10:27 AM   #13
DuskSS
DuskSS's Avatar
Hope this helps.
Um duh read all the responses before going off half ****ed
Sent from my SPH-L900 using Tapatalk 2
530/520 SAE
Old 03-25-2013, 10:33 AM   #14
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
I paid $10 at my dealer with lifetime top up.
ajp is offline   Reply With Quote
