01-24-2015, 07:30 AM | #1 |
"Katy"
Drives: 2014 2LT A6 'Vert Join Date: Feb 2014
Anyone that has done a CAI, question about the windshield washer tank?
I am looking to do a cold air intake, and I see that most if not all of them encloses the windshield washer inlet. For anyone that has done a CAI, did you leave the tank inlet alone? Did you purchase a Washer Fluid replacement kit?
What about a intake scoop? Pro's and Con's of either?
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake Possible next mods: Throttle Body Exhaust Upstate C5 Member No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars.... |
01-24-2015, 08:21 AM | #2 |
Drives: 2012 camaro 1LS. M6 Join Date: Sep 2012
I have not moved my tank & it's no big deal to add washer fluid but I don't drive mind a lot .I have noticed a better sound and performance ... I can't respond about using the scoop I hope this helps
Mods..mrt v2. Cai intake v max throttle body. 20% windo tint & RX catch can Gianna 20in rims nitto 555 & afterburner tail lights RS halo head lights & gm heat extractor 4 pack gauges & panted heritage Grille & zl1rear sproler t5 splitter custom head rest
01-24-2015, 08:30 AM | #3 | |
Drives: Summit White 2014 1LT Join Date: Feb 2012
I have the CAI Inc system and the lid Covers the washer bottle,which isn't a big deal...I keep a torx driver in my glove box. I haven't done the washer bottle replacement either, but have been thinking about it only if I do the scoop...which I'm still thinking about myself. So, in short, I didn't do the washer bottle relo or the scoop. Lol |
01-24-2015, 08:30 AM | #4 |
i didnt relocate my WW tank nor have I have added the scoop. it isn't too hard to add washer fluid tho. the cover for the CAI brand intake comes off fairly easy.
01-24-2015, 11:11 AM | #5 |
"Katy"
That's kind of what I was wondering, how easy is it to fill with the CAI around it.
01-24-2015, 11:12 AM | #6 |
Drives: 2013 Camaro RS 1LT, 6M Join Date: Jan 2013
You all should do the scoop I relocated mine washer bottle however. Put in the scoop not hard to do and you get better airflow. No sense of having a CAI if you not letting air in right.
01-24-2015, 11:16 AM | #7 | |
Drives: 2016 Bright Yellow 2SS A8 Join Date: Jul 2014
01-25-2015, 01:33 PM | #8 |
Do somethin fun every day
The stock WW tank is enormous and in the direct path of airflow. I pulled mine and put in a Rotofab tank which fits nicely up top behind my CAI cold air intake box. Looks good too. I also installed the air scoop, it couldn't hurt.
01-25-2015, 01:38 PM | #9 |
I run 2 catch cans...
I had it both ways, and with the air scoop it woke up the CAI. I had my horn bolt replaced in 10 seconds, and I unscrewed it with my hand. I made my own replacement washer bottle; the OEM one holds about a gallon of juice that is un-needed weight.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
01-25-2015, 01:39 PM | #10 |
750HP of Twisted Reaper!
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes Join Date: Oct 2010
+1.....i actualy didnt do the scoop initially, but i did it a year later with the Washer bottle relocation kit and it ran better to me....or at least thats what my butt dyno said!
Fear the LMR Twisted Reaper Brotherhood!
01-26-2015, 04:24 AM | #11 |
"Katy"
Thanks for the responses everyone, some things to think about when I do this. I was leaning towards doing all 3 at the same time rather than doing the CAI first, and then having to change it later.
01-27-2015, 01:31 PM | #12 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
Volant makes one with a pre-made hole fits over the washer fill
01-27-2015, 03:03 PM | #13 | |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
Secondly, although many people run the scoop/washer bottle relocation kit and are very happy with it, don't feel like not doing it will cause you grief. The lid comes off in seconds and is held in place with 3 spring loaded fasteners, and I'm guessing you wont be filling your washer fluid all that often anyways. So for the few times a year you have to add some fluid, taking the cap off the washer fluid will probably take nearly as much time as taking the lid off of your CAI If you have any questions, feel free to let us know, thanks! |
01-27-2015, 04:35 PM | #14 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
I added a scoop to mine and removed the washer tank. I do t use the wipers so the washer fluid is pointless. Weight savings
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
