Roto-Fab
Old 12-01-2017, 04:36 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Squash E85 Fuel System With Heartbeat
The system will be installed at Mullinex Raving Engines in Simi Valley CA!
http://www.mullenixracingengines.com
What do you predict squashes best fuel setup and E-85 will put down on the dyno with the mod list below pre-existing on the vehicle? We will be posting dyno results once the kit is installed! Stay tuned.
Update!!! Fuel system has arrived and installation will be taking place this upcoming weekend followed by tune on the 15th!
Nighthawk89 is offline   Reply With Quote
Old 12-01-2017, 06:36 PM   #2
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Hopefully you have Rods and pistons. Also the ID850 will be to small on E85 if you push it much.
700 ish
Slickcas is offline   Reply With Quote
Old 12-01-2017, 08:03 PM   #3
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
Agreed. Upgrade the injectors and unleash the beast!
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 12-01-2017, 09:12 PM   #4
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Trap speed > dyno number.
Unavowed is offline   Reply With Quote
Old 12-01-2017, 10:04 PM   #5
Nighthawk89
Injectors will be upgraded to either FIC or ID's at 1000's or larger!
Old 12-02-2017, 07:10 AM   #6
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
agreed
ttshovel is offline   Reply With Quote
Old 12-02-2017, 07:21 AM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
It is really going to depend on boost level.
At 17 psi if the combo is right it will make 850 RWHP.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-02-2017, 08:39 AM   #8
Nighthawk89
Do you think its safe to run over 10psi on otherwise stock internals? I was hoping for 13psi..
Old 12-02-2017, 08:45 AM   #9
ttshovel
ttshovel's Avatar
I abused my stock bottom end motor with 19psi with the lsa on e85. never had an issue. it's all in the tune!
Old 12-02-2017, 08:55 AM   #10
JANNETTYRACING
With E-85 you have way more head room than you would on 93
I would have no issues with running 14-15 psi on E-85
But you must also accept that you are still on stock internals and if you can't afford to break it put your greed for power aside until you can..
Ted.
Old 12-02-2017, 05:55 PM   #11
Nighthawk89
Ted.
I wish we had 93 octane out here in southern California!! Im stuck with 91 trying to push whatever I can conservatively. I can certainly afford a rebuild I just have had my faith in my tuner thus far, hoping the stock block withstands this last round of mods! Maybe Ill drop one pulley size and see what that will produce..
Old 12-06-2017, 06:23 PM   #12
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
Breathe! I was @ 13 for years on E-85. You'll be fine. Just don't do like I did and miss a shift, over rev and destroy a lifter......
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 12-09-2017, 09:22 PM   #13
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Devin is just scared af!
E85 ftw I'll still push your shit in dig or roll, Devin.
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 01-07-2018, 06:42 PM   #14
Nighthawk89
Only another week! Not looking like I'm going to up the boost until i change over to a 10 rib setup..
