08-19-2020, 05:41 PM | #1 |
Drives: 2016 2SS Join Date: Dec 2017
White SS ralley strips deteriorating
2016 2SS Factory strips looking terrible. Yes I live in Arizona sun and use a automatic car wash. Everyday driver. Is there a better product or should I eliminate them. If taken off, will I see whittness lines. Any input appreciated.
Thx Scot |
08-19-2020, 05:43 PM | #2 | |
2020 Shadow Gray 2SS
Your best bet is to probably get them replaced.
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
08-20-2020, 12:45 PM | #3 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
08-21-2020, 06:30 PM | #4 |
Drives: 2020 Camaro RS Join Date: Oct 2019
Yes, you will have decal ghosting.
As to whether you should replace the stripes there's a couple considerations. First, do you like the stripes? If so, replace them. Second, you should have paint correction done in either case and proper paint correction may remove the ghosting. So I would suggest removing them and get the paint corrected. If the correction eliminates the ghosting then you can chose between replacing the stripes or leaving it without. If the paint correction doesn't eliminate the ghosting then replace the stripes. JMHO No expertise implied or expressed.
RWT
2020 Camaro RS, V6, 6MT, Satin Steel 2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray 2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic |
08-21-2020, 07:19 PM | #5 |
Thinking about removing them and just having the stripes painted. Do you think I still would need paint correction or possibly making them approximately an 8th inch into the Black. I’m not a painter. would paint peel because of the line and or would it need to be clear coated . Don’t want to deal with this again in another 3 to 4 years.
Thx Scot |
08-21-2020, 07:28 PM | #6 | |
08-22-2020, 11:46 PM | #7 | |
I like the way you're thinking. I am not a fan of vinyl anything on a vehicle. Any stripe worth having is worth having painted (IMHO). That said, it would not be easier or cheaper. Yes, it would still require paint correction. No professional painter with any integrity is going to paint over damaged/uncorrected paint (unless they're preserving patina). I imagine they would wet sand/prep your entire hood, paint your stripes then clear coat the entire hood. Properly painted with high quality paints, the hood finish could outlast the rest of the original finish. A poor quality job with low quality paints won't outlast your vinyl. Professional painting would be your most costly but most durable and best looking option. The other consideration is post repair maintenance. The Arizona heat and sun are very hard on paint. A proper maintenance program can fend off future damage. Your paint needs protection or you'll just be chasing your tail. No expertise implied or expressed
RWT
