04-11-2024, 01:12 PM | #1 |
Drives: Camaro 2SS 2017 Join Date: Jan 2022
extreme negative fuel trims
Hello guys i've had issues where the car runs extreme negative LTFT at -20 to -35 on both banks and the car runs pretty rough on idle and i get constant small pops and crackles everytime i let off the gas. No codes whats so ever and car still answers good when i actually floor it with no missfires or anything. Changed O2 sensors and high pressure sensor but that did nothing. Do i have a bad HPFP?
Big thanks for any advise
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT 2Forge 19" wheels daily, Forgestar D5 17" for track |
04-11-2024, 02:19 PM | #2 |
Drives: Chevrolet Camaro Join Date: Apr 2022
Have the fuel trims always been negative since it was tuned? Any changes since the tune? Pull the MAF and clean it.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
04-11-2024, 10:10 PM | #3 |
No the trims were pretty perfect after the tune but now they’re way out of whack. I’ll try with that thanks.
04-12-2024, 06:29 AM | #4 | |
Does your exhaust smell like gas? Sounds like you are dumping fuel into the exhaust. |
04-13-2024, 02:45 PM | #5 |
definitely does smell alot of gas. Maybe dirt? Injectors has been driven about 2000 miles and we followed all procedures that came with them from FIC. And it seems all injectors are off. Isn't that odd? Pressure set at around 2150 psi and car doesn't stumble or anything when going above 3k rpms. I'm very much a beginner at this. My tuner says he still has the rear 02 sensors on and he was following advise from Ted at Janetty that they shouldn't be turned of. Definitely not trying to point any fingers as i know Ted is great at this but maybe there was a misunderstanding with my tuner and i being Swedish lol
04-13-2024, 03:30 PM | #6 |
Your front O2 sensor is the one used to adjust the air/fuel mixture. We know that is working because your car is setting the fuel trims to reduce fuel. For some reason it is not able to reduce the flow from the injectors, even by going to extreme negative fuel trims.
Are these the stock injectors? The back O2 sensor is used to verify the catalytic converters are doing their job. The reading from back O2 sensors does not affect the air/fuel mixture. I am not sure of everything you have done to modify your car. You may also need to upgrade to a wide band O2 sensor. But it sounds like your current setup is trying to correct the problem, but too much fuel is getting through. |
04-13-2024, 03:36 PM | #7 | |
04-13-2024, 08:15 PM | #8 |
Make sure you don't have any burnt plug wires, could be misfiring showing a rich condition and the car is trying to pull fuel out.
04-14-2024, 10:43 AM | #9 |
no missfires what i can see on the logs. Car just runs super rich
04-14-2024, 08:40 PM | #10 |
Still worth checking, might not show up on a log since it's probably intermittent. You say you can feel it misfiring but no codes have popped up.
04-15-2024, 07:40 AM | #11 |
04-15-2024, 11:26 AM | #12 |
Have you checked the oil?
04-15-2024, 11:53 AM | #13 |
04-15-2024, 12:42 PM | #14 |
definitely has oil dilution. 100% smells like gas.
