Old 08-01-2017, 04:09 AM   #1
BFella
BFella's Avatar
Drives: 16' Supercharged 1SS
0-60 Times While Supercharged?
Okay, so I have a Maggie TVS2300 - Box tune with it and factory airbox and still at 6psi. I also have Michelin PS4S.
The best time I got tonight was 4.1 secs - I did have traction control on. I ran it multiple times but that's the best I got.
Should I be concerned at all with this?
760RWHP Magnuson 1SS
BFella is offline   Reply With Quote
Old 08-01-2017, 04:48 AM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
You need some track time. The street just won't tell you much. Too much spinning. I ran 10.82@129 on pretty much the basic Maggie tune. I wouldn't be concerned. I did have the drag pack and not on street tires. Have you had yours on the dyno yet? You should be close to 540 at the wheels.
Old 08-01-2017, 04:59 AM   #3
BFella
BFella's Avatar
No, I'm gonna get it on the dyno I think this week to make sure it's all good. But yeah every launch I was spinning, so that could very well be it.
Old 08-01-2017, 07:36 AM   #4
laynlo15
laynlo15's Avatar
Oh that's it, too much power for good times
Old 08-02-2017, 11:04 AM   #5
1968ss350
1968ss350's Avatar
Drives: 1968 Camaro SS 350
hahaha man i have the same problem... with that kind of power we need the "drag pack" like laynlo said for sure. Slicks and skinnies. I am still running the stock good year 275s and they spin through first and second even when easing on it. I may get some wider wheels and tires for the street....
1968 Camaro SS 350 Lemans Blue
-350 10.4:1 comp, Edelbrock Etec 200 heads, Comp XR288HR cam,AED750dp worked, Tremec TKO 600, console gauges w/tic toc tach, Moser 12 bolt, 4 wheel Willwoods
Hyper Blue 2SS/6 speed, NPP, MRC, Nav, 5LQ 6 piston brakes, Black split spoke, Magnuson 2300 Heartbeat Supercharger, Flowtie upper grill
1968ss350 is offline   Reply With Quote
Old 08-02-2017, 11:40 AM   #6
grampa_ss
grampa_ss's Avatar
Drives: 2016 Camaro 2SS
Nitto 555R's. Good for DD and hook very well.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth.
grampa_ss is offline   Reply With Quote
Old 08-02-2017, 11:58 AM   #7
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
What were your times before supercharger?
Also, with the heat down there, this may be a decent number. I was in Scottsdale week of July 10. one night at 10:30PM it was still 102° outside. And what's your altitude...like 1000 feet?
I'm at 6200 feet altitude and best I could get pre-supercharger was 5.7 seconds (yes we lose that much power up here). My best after is 4.7.
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
DenverTaco07 is offline   Reply With Quote
Old 08-02-2017, 01:42 PM   #8
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
listening.... I have Michelins PS4S so I'd assume they are just as good as the 555's.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 08-02-2017, 03:02 PM   #9
BFella
BFella's Avatar
The Michelin PS4S are LIGHT YEARS ahead of the triple 555s lol.
Old 08-02-2017, 04:39 PM   #10
grampa_ss
grampa_ss's Avatar
had no idea PS4S hooked better that Nitto 555R drag radials. Learn something new every day.
Old 08-02-2017, 05:46 PM   #11
1968ss350
1968ss350's Avatar
PS4S is better than a DR?....
Old 08-05-2017, 05:34 AM   #12
BFella
BFella's Avatar
Didn't see the R :P
Old 08-05-2017, 02:58 PM   #13
attymf
attymf's Avatar
Drives: 2017 SS
I ran 4.2 best on street stock everything. Procharged with M&T's I am running 3.3 on the street. I dont do anything but mash the pedal. Leave everything on.
SS, A8, Procharger, M&T's and stuff...
attymf is offline   Reply With Quote
Old 08-05-2017, 03:36 PM   #14
bucknut2006
Drives: 2017 ZL1 A10, 2015 C7 Z51
The 555R's are pseudo drag radials. They require a lot of heat to stick and are not consistent. The NT50R is the better drag radial and closer to a Mickey Thompson.
2017 Camaro ZL1 - Nightfall Gray Metallic - A10 - Roto-Fab intake
bucknut2006 is offline   Reply With Quote
