Old 09-12-2016, 08:07 AM   #1
mjmenke
mjmenke's Avatar
Drives: 2017 Camaro SS
2017 2SS automatic baseline Dyno numbers
422 HP 427 TQ
2017 2SS Black NPP A8 - 422 HP 427 TQ
mjmenke is offline   Reply With Quote
Old 09-12-2016, 10:00 AM   #2
parish8
Drives: 17 SS a8
How many miles are on the car? What gear did you run in?
I ran mine on a dynojet which is typically a little higher than others and only got 386rwhp. 400miles and in 6th gear.
parish8 is offline   Reply With Quote
Old 09-12-2016, 10:15 AM   #3
mjmenke
mjmenke's Avatar
~2500 Miles. 5th gear.
I asked about this. They said 6th gear is too long of a pull and they said I could even do 4th. They calibrate the dyno to the car by measuring the tire diameter and then run the car at 3000 rpms to calibrate the dyno to the car. So they claim it doesn't matter which gear. I'm just repeating what they told me.
I went with 5th because the final combined gear ratio is the closest to a manual transmission in 4th (1:1). This seems to be the general consensus around here IMO.
They have done 3 camaros that I know of at the monthly Cars and Coffee this year.
2016 manual 417/412 - member here and I was present.
2017 auto 436/433 - brand new pace car convertible and is currently sitting on the showroom floor. They did this one right after I left last month.
2017 auto 422/427 - myself
After my dyno the manager came to me and said they just did a 2017 Manual that did almost 470 after headers, CAI and a tune.
Old 09-12-2016, 10:18 AM   #4
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
That is a very generous dyno and shows why trying to compare #'s from different shops is almost useless. Some people get 386 on a Mustang, someone gets 402 on a Dynojet, etc....
avalonandl is offline   Reply With Quote
Old 09-12-2016, 03:41 PM   #5
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
+1
The SAE Certification alone shows just how inconsistent dynos are
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 09-12-2016, 04:33 PM   #6
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
A/F ratio is a max of 10.04 ??
Old 09-12-2016, 04:38 PM   #7
mjmenke
mjmenke's Avatar
Ignore AFR and boost. Nothing was hooked up to the car to record them.
Old 09-12-2016, 04:40 PM   #8
SpeedIsLife
Drives: Current Camaro-less
I'd go find a nice Mustang Dyno and get that done...at least then the numbers will be more real-world realistic.
SpeedIsLife is offline   Reply With Quote
Old 09-12-2016, 04:41 PM   #9
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
X2
Old 09-12-2016, 04:51 PM   #10
mjmenke
mjmenke's Avatar
Assuming 10 percent drive train loss.
430x.9=386
455x.9=410
470x.9=423
Old 09-12-2016, 05:09 PM   #11
BadBowtieProductions
Check me out on YouTube!
BadBowtieProductions's Avatar
Drives: 2016 Camaro SS
6th is 1:1, and it does 193 on the dyno. 5th will of course give a higher number, and as other said, take dyno numbers with a grain of salt. Either way, congrats on the purchase.
2016 Camaro SS - A8, NPP, 2SS, Nightfall Gray Metallic
11.68 @ 118 - CAI Intake - TSP 2" Longtubes - DSX Tuning Flex Fuel - DSX Tuned
11.91 @ 117 - CAI intake only
11.99 @ 117 - STOCK 1/4 mile
410 RWHP / 424 RWTQ - STOCK Dyno
YouTube Channel: BadBowtieProductions
BadBowtieProductions is offline   Reply With Quote
Old 09-12-2016, 08:40 PM   #12
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
Man those are great dyno numbers , Id like to see how much the car traps In the 1/4 to see how that rwhp translates into speed.
z28pat is offline   Reply With Quote
Old 09-12-2016, 09:58 PM   #13
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
430x.9=386
455x.9=410
470x.9=423
You have an automatic, 10% loss is for a manual. I think the A8 is more like 15-17%. Plus, as another said below, your dyno operator should have used 6th gear and may have also put in the wrong final drive ratio. Congrats on that sheet of paper, but it is highly inaccurate.
JaxChris is offline   Reply With Quote
Old 09-13-2016, 12:50 AM   #14
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Most dynos will not let you do a 6th gear pull. You will most likely reach the dynos top speed well before redline.
Sledgehammer70 is offline   Reply With Quote
