TireRack
View Poll Results: How long till you open it up???
After 100mi 3 4.05%
After 100mi but not driving it all at once 4 5.41%
After 250-500mi 17 22.97%
After 250-500mi but not driving it all at once 19 25.68%
OPEN IT UP OFF THE LOT!!! 31 41.89%
Voters: 74. You may not vote on this poll
Old 03-08-2008, 08:02 PM   #1
Emu the Foo
Emu the Foo's Avatar
Drives: 92 Cadillac Sedan DeVille S/C
Send a message via AIM to Emu the Foo Send a message via Yahoo to Emu the Foo
To break in or not to break in?
so i want to drive this thing but i personally refuse to go over 80mph in this car till atleast the first 100mi. now friend says its not necissary at all to break it in, not sure how much i trust him. so i decided to just drive around in it till i reach one hundred miles to open it up. my gf says that vw told her not to drive it long distances for a little while. im not sure what to do. how many of you would do what till you open it up? do you need to break these new engines in at all? of course i mean the camaro
I JUST WANT MY 400+ HORSES
Emu the Foo is offline   Reply With Quote
Old 03-08-2008, 08:04 PM   #2
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
First off what vehicle are you talking about in the first place. Second of all, read this website.
http://mototuneusa.com/break_in_secrets.htm
Kyle2k is offline   Reply With Quote
Old 03-08-2008, 08:12 PM   #3
Emu the Foo
lol, nice. i was going to go to vegas when i got the car on a weekday. its 258mi frm where i live. i can break it in on the way then do 140 on the way back
Old 03-08-2008, 08:27 PM   #4
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
uhm WHAT CAR DAMNIT ....lol Make sure you read that sight though, don't beat the crap out of it, youre supposed to vary acceleration and not sustain speeds for extremely long distances.
Old 03-08-2008, 08:39 PM   #5
Emu the Foo
on the camaro. what else would i do. and i figure no more than sixty for the first 20mi (10 min for me) then get the oil change and then go to vegas. then ill get another oil change in vegas and head home. ill go frm 30 to 65 then to 30. sounds good or what flaws are there
Old 03-08-2008, 08:45 PM   #6
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Well, I would drive it hard ( no clutch drops lol) but hard for the first 25 miles, get an oil change. Then just vary it and get through all the gears at different rpm ranges. oh and use real oil for the first 1000 miles, then switch to synthetic, another reason driving it hard (but not beating on it) helps is because it seats the piston rings.
Old 03-08-2008, 09:13 PM   #7
09'Z28
The "Mad Hamster"
09'Z28's Avatar
well typically you are supposed to wait a couple hundred miles but it usually say about how many miles to wait
Old 03-08-2008, 09:25 PM   #8
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Everyone should really just look at the sight I posted it says it all right there...babying it doesn't seat the piston rings and cause crap to happen in later engine life.
Old 03-08-2008, 10:33 PM   #9
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Your friend is partially right. (I didn't read that link, but rather am using infinite wisdom passed down from GMHTP magazine )
The breaking-in period isn't a huge issue as much as it was. However, it still exists (the need for a break-in). How long you take is up to you. They advise ~500 miles, I think. The reason is to seat the rings (like said above). And city driving is preferred to do that. Because a constant rpm is only going to seat the rings at that speed, not the rest (over-simplification). Opening her up once of twice isn't going to kill it. In fact, it may help out the break-in process.
Also - as I think was mentioned above, get an oil change earlier than you're supposed to. Because the first round of oil is gonna get REAL crappy, real fast with all the wear on the brand new parts (mainly the rings).
So: change the oil early. Don't go road racing for AT LEAST 200 miles (imho), and vary the revolutions (minimize highway driving).
Hope that helped.
EDIT: I just read the link posted up...and although technically it's the same thing (motors and all) I'd rather not rely on guides for BIKES (and other small vehicles like that) to break in my CAR. (call me picky )
Here's the GMHTP article I was referring to. Don't want any of you to think I'm pulling this stuff out of thin air.
THE BIG BREAK-IN
OK, so it runs--good work! But your big-cube engine isn't quite ready to impress your buddies on joy rides, much less hit the local drag strip--and we're not just talking about making sure the tune is dialed-in (more on that momentarily). Anyone who knows the least bit about automobiles has heard the shpiel that new engines need to be "broken in." Going through this procedure ensures optimum power output and long component life, but what exactly is going on here, and what's important to know for the Gen III?
During the first several hundred miles of operation, the metal parts of the engine "mate" to each other. While advances in technology mean that engine parts are manufactured to more exacting tolerances than ever before, the microscopic uniqueness of any one piece of metal that comes off of the assembly line or out of a machinist's cylinder honing machine continues to endure. Think of this mating like the last step in machining: all surfaces that contact one another "wear" or "finish" each other to the point they'll operate at for the rest of the life of the engine. We want this initial wear-in to occur, but if we try to get it to happen too fast, the engine parts will instead wear out prematurely.As far as GM small-block engines go, allowing flat-tappet lifters to properly mate with the camshaft lobes was a huge concern back in the day. This necessitated special lubricants, and also required the engine to be spun above a minimum rpm for the moments following initial start up. Happily, those days are ancient history, and thanks in part to this advance, no elaborate, "ceremonial" break-in is required for an LS1-based engine. But our beloved V-8s still have important parts like bearings--and most significantly, piston rings--that require a wear-in period to operate properly.
So, how to go about this? We spoke to Mark Chacon, Lunati's East Coast Regional Rep., about his thoughts on this issue. "As motors are breaking in, and in regards to piston ring seal, they want a constantly changing engine rpm environment. This is why city driving is generally the optimal condition for any motor break-in. The worst thing that you can do with a new engine is to put it together, fire it up, and then head down the interstate with the cruise control on. While a little bit of freeway driving is OK, certainly for the first 500 to 1,000 miles I would try to avoid long trips or periods where you're operating at a constant engine speed," says Chacon.
OK, so staying at any one engine speed is bad, but this isn't to say you can go take your new engine to six grand the first time out. On the contrary, restraint must be used to keep engine speeds and loads reasonably in check. "Don't go out there and just hammer through the gears all the time; you need to be a little more conservative about how you drive the vehicle. A varied range of rpm usage, combined with keeping it easy on the motor, allows the face on the ring to do a better job of seating to the cylinder wall," says Chacon.
The type of fluid used during break-in is also important. You may have heard that synthetics are "too good" to use during the first miles on a new engine, and this is true. The main reason for this is the piston rings, which as we have said need time to seat to the cylinder walls properly; if they don't, horsepower and efficiency will be left on the table thanks to reduced cylinder pressures. Mark Chacon elaborates: "The ring face must have ample time to break in to the cylinder wall finish, and running a conventional oil for the first 1,500 miles or so will aid this. Ring seal needs to be firmly established before synthetic is introduced into the motor, and one of the reasons the factory LS1 has such a heck of a time with ring seal to begin with, in my view, is that many come from the factory with synthetic oil in them. Once you put synthetic in, what you've got is what you've got, and the rings may never really wear to the cylinder walls. Of course, feel free to eventually switch to synthetic because of its better properties, but make sure the rings have seated fully first; short of using a cylinder leakdown tester, mileage accumulation is the only way to tell whether this has occurred."
As engine parts wear in, more small metal particles are being cast off into the engine oil than would usually be expected. Therefore, keeping the engine oil clean during the break-in period is essential. In furtherance of this, be sure to use a high quality, high capacity filter that can capture very fine particles. As to fluid change intervals, a good rule of thumb from Lunati is to drop the oil after 100 miles to get the initial bearing cast-off material out of the system. Then, change the oil after 500 miles, and again after 1,500 miles have accumulated, from which point forward you can follow manufacturer-recommended change intervals and swap to synthetic oil if desired.Stick to these simple driving and engine oil maintenance tips during the break-in period, and you will help your stroked LS1 live a long, happy life under your GM performance car's hood.
http://www.gmhightechperformance.com...ild/index.html
Old 03-08-2008, 10:56 PM   #10
NOODLESgoneWILD
IS IT 2009 YET???
NOODLESgoneWILD's Avatar
Drives: '05 Z51 Black Vette & '06 H2
Send a message via MSN to NOODLESgoneWILD
Hope that helped.
Thats very sound advice Dragon!...
First thing of the lot, I plan on filling up the tank...
cruz around down town seattle...
then down to Alki Beach...
then maybe over to the ocean for a nice twisty drive...
Find a nice place to stay the night, Do a photo shot by the beach at sun set...Cuz this is our (me and the maro) honey moon... ...
Then the next day hop on the freeway for a nice cruz home... which has few spots I can open her up and see what shes got...
That will be the best weekend if my (our) life...
Don't love me just for my FBod
NOODLESgoneWILD is offline   Reply With Quote
Old 03-09-2008, 12:26 AM   #11
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
As far as filling up the tank as soon as you get off the lot, you should know that a full tank of gas is always included in the price you pay for the car. Look at the window sticker. A full tank of gas is actually listed as a standard feature. So you should never drive off the lot with anything less than a full tank.
I've heard about 400ish miles, so pretty much what Dragon said. The advice I've heard said to drive like you normally would, just at 80%. So just drive your normal commute, but don't pound on the thing. It is generally not a good idea (for many reasons) to do a burnout driving it off the lot. And yes, while driving your normal routes during the break-in period, try to vary the RPM more than you normally would. And to echo Dragon, get the oil changed at the end of the break-in period, then follow the manufacturer's schedule after that (GM includes computers that tell you when to change based on driving conditions, not mileage.)
stovt001 is offline   Reply With Quote
Old 03-09-2008, 01:20 AM   #12
Emu the Foo
the DIC should tell it all. yeah, my original plan was to get an oil change after 20mi and use only non synthetic oil for the first 1500mi. then frm there on race stangs, civics, tCs, and even fiestas with racing stripes
guess i hold off on the vegas trip. in the mean time i can get the windows tinted and let them dry. i always let 5 days to dry. also taking day after i get it off frm work. but i really work my own schedule, so i can cruz inbetween days
Old 03-09-2008, 05:09 AM   #13
Camaroman_99
Camaroman_99's Avatar
Drives: 2009 Jeep Wrangler Unlimited
Probably get a few hundred miles on her before "dropping the hammer"
Camaroman_99 is offline   Reply With Quote
Old 03-09-2008, 06:07 AM   #14
Emher
Pillaging Viking
Emher's Avatar
Drives: Saab 9-5 '99 (Hey it's a GM!)
Send a message via MSN to Emher Send a message via Yahoo to Emher Send a message via Skype™ to Emher
Oh great, the closest Chvey dealer is 50 miles away on the highway...guess I'll take the small roads home for a bit then.
"Fifty years from now, when you're looking back at your life, don't you want to be able to say you had the guts to get in the car?"
Emher is offline   Reply With Quote
