06-03-2018, 06:36 PM | #1 |
Drives: 2011 2SS/RS Callaway Join Date: Feb 2014
What is this vibration? Advice appreciated
Hey there, my car started vibrating and it seems to be getting worse. I dont drive the car that much because its been in the shop getting random things done but i noticed it about 100 miles ago on a high speed run in Mexico I’m now feeling it doing 50. When driving the car it only happens when you are accelerating. As soon as you push a little bit of gas over 50 mph you can feel it and it increases as you go faster. But when you let go of the throttle, it stops. So its only on load. My shop thought it was my driveshaft and I replaced it with a one piece aluminum from DSS and it still does it. I have Gforce upgraded axles and on the drivers side axle, a little bit of grease is coming out. Its not a ton but its coming out. Could it be that axle? I’m not sure. But the axle is spinning the whole time, so it should do it, i think, regardless of the car accelerating or decelerating. I still have my old OEM axles and might try that. They are going to do a high speed balance on my wheels just to rule that out. But I dont think its my transmission or my rear end but im not sure. Does anyone have any ideas what they think is happening?
2011 Callaway SC572 2SS/RS, TVS 2300 Supercharger, 1-7/8" Kooks LT Headers, Fast 85# injectors, E85 Flex Fuel Conversion, Fore Twin Fuel Pumps, MGW flat stick short throw shifter, McLeod RXT twin disc clutch, Liberty Gears Tremec trans, DSS 1000 hp axles, Nitto NT555r drag radials, 10#'s of boost, 702 rwhp/ 697 torque, Recaro seat upgrade
06-03-2018, 08:50 PM | #2 |
Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
Have the engine mounts checked out.
06-03-2018, 08:57 PM | #3 |
Fast Cars and Old Guitars
Where do you feel this vibration? And what frequency is it, as in, the steering wheel of seat of the pants? More engine or tire/wheel rpm?
06-05-2018, 02:36 PM | #4 |
Drives: 2013 Camaro 2SS Inferno Orange Join Date: Apr 2015
bro ive been chasing one for a year now man still no luck. im well over 5k in parts that ive changed thinking that was it. ( i needed the parts any ways for my power level)
if you find anything out let me know |
06-05-2018, 04:50 PM | #5 |
Drives: 11' RJT 2SS/RS L99 Join Date: Jun 2014
Yeah ive got a similar vibration except i feel it over 25 mph. I only feel it on acceleration as well. I checked the driveshaft and there were no loose or broken bolts. The axles look good as well. Im starting to think it could be the exhaust.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall 1LE 3.91s Stainless Power Headers w/cats Fluidampr 25% UDP Cold Air Inductions Intake Bo White Ported Throttle Body ADM Trans Cooler Some BMR Goodies |
06-06-2018, 10:12 AM | #6 |
I had a similar issue, honestly just kept driving it and it went away in around 1k miles or so by itself
2010 Camaro 2SS/RS
06-06-2018, 11:30 AM | #7 |
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn Join Date: May 2009
Good luck with trying to isolate a vibration, there`s so many rotating and moving parts of a car that you`ll probably go broke replacing suspected parts or insane before you find the problem.
Free Trade is not Fair Trade
I am, we are INDIVISIBLE Invictus, By William Ernest Henley |
06-06-2018, 12:01 PM | #8 |
Drives: 2011 Vistory Red 1LS Join Date: May 2018
Kind of a stupid idea maybe, but could you maybe have a loose exhaust piece?
The Original Farm Rat
2011 1LS M6 Victory Red Sold 1967 Coupe Green and White 1969 SS 396 Hugger Orange 1969 Z/28 All original White with deluxe interior 1970 RS Blue 1978 Coupe Fugly Green 1978 WS-6 Trans-Am Factory 4 speed 1985 IROC-Z Red |
06-06-2018, 02:13 PM | #9 |
Or lug nut(s)?
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
06-07-2018, 12:07 PM | #10 |
old school chevy rodder
the usual Idea is the slop in bad u joints...… It happens under load being more key to it. Good Luck. I don't know what you have done to stiffen the rear or what I use poly bushings LPW cover, BMR////
06-07-2018, 12:13 PM | #11 |
are they good vibrations and are they giving you excitations? :P
06-09-2018, 05:39 PM | #12 |
Well, we found the vibration. It was my axles. We put on my old OEM axles just to eliminate an option on what it could be and that was it. I thought the vibration was happening at higher speeds but after we changed the axles the car drives so smoooth now. It blows my mind that i went thru two sets of aftermarket axles and both failed from two different companies. The good news is the Gforce axles have a life time warranty and they will get fixed. I’m going to leave the stock ones in until they break and have the Gforce as a backup. Thanks for all the help and recommendations.
06-09-2018, 08:29 PM | #13 | |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
