07-04-2013, 04:55 PM | #1 |
Drives: 2010 Chevy Camaro 2SS/RS Join Date: Nov 2012
To sell or not to sell!!
Ok,I own a 2010 SS auto in summit white. I had the car sent to me all the way from the states to Dubai.
Everything was great until a recent incident where I was driving around an abandoned road. Quite honestly,I was pushing the car to it's limits,miscalculated a sharp turn and came off and damaged the suspension. I had loads of issues finding a garage I could trust to get the job done right as the local Chevy dealer in Dubai will not work on my car due to it being an import! Eventually found some one I thought would know what their doing. I was wrong!!! The car is back but nothing like it used to be. I feel a lack of power,engine is strong and rev's hard but don;t feel the power is being put down through the wheels. Crap loads of vibration at 80 kph. Traction control light on,stablitrak service msg,tire pressure msg etc etc I loved the car but why have a V8 with v4 power!! There is no way the car is even making 300+ hp I have no clue what to do. Keep it and spend more and attempt to get it back to the way it used to be or get rid of it. Not even sure where to start if I was to keep it. I was thinking to Dyno it? Than tune? Replace all sensors?? spend mpre $$$ dollars on suspension when I've already replaced everything that was damaged with OEM parts. This is driving me nuts!!!!!!! |
07-04-2013, 04:59 PM | #2 |
Drives: 2011 Chevy Camaro Join Date: Sep 2010
Lookup mike from new era performance. He goes over there a couple times of year and could look at it. He is from Rochester ny.
07-04-2013, 05:09 PM | #3 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
Sounds like your car is in limp mode. If they replaced a bunch of the suspension maybe they screwed up the ABS or something.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
07-04-2013, 06:30 PM | #4 |
Drives: 2010 Camaro 2SS/RS IOM L99 Join Date: Jun 2013
I heard that locally in Dubai that the people would pay twice as much for a Camaro because its rare over there. Not sure if its true but had an acquaintance sell his used SS for $50,000.
-RotoFab CAI
-Kooks LTH -Ported TB -SLP Loudmouth I Muffler Delete -V8 Only Range Device -Technostalgia Advanced Taillights -Elite Engineering Catch Can -Anvil Notch Spoiler |
07-04-2013, 11:54 PM | #5 |
07-04-2013, 11:56 PM | #6 | |
Imports are cheaper. |
07-05-2013, 02:40 AM | #7 |
C'mon guys! Chime in! Help a brotha out!
07-05-2013, 05:17 AM | #8 |
Drives: 2SS Join Date: Sep 2012
when you start the car, what error codes do you have in dash?
07-05-2013, 05:19 AM | #9 |
also describe us where the damage took place and what oem parts you changed....that might help us understand what happened. Be specific!
07-05-2013, 02:28 PM | #10 |
I changed 90% of the suspension components on the right side,so shock absorber,springs,control arm,end link,bushing etc
I'm finding it difficult to let go of her but I am nearly there. I think it's the end of the road. I like my cars mint and problem free and I don;t really feel I can restore her to her former glory! |
07-05-2013, 03:36 PM | #11 |
First of all I do believe an abs sensor is down...that is why you see service stabilititrack and also abs errors or so. Regarding the vibration, assuming you have done a PROPER alignment start by centering your wheels on the car hub, if that does not work make sure the wheels are properly balanced. If this doesn`t work a rotating assembly might be bent. Do you feel the vibration in the front of the car or at the back? If you let go the wheel does it try to go to the right or left or is it neutral?
I see you also have a tire pressure light on, the sensors from the car could have gone wrong or the mechanics could have put the front wheels to the back...or the sensors from the wheels. Before you decide to sell take into consideration that american cars are the simpliest cars to work on, you should not give up on it before you know for sure what is the problem. |
07-05-2013, 04:06 PM | #12 |
Drives: 07gt Join Date: Jun 2012
I have been under the camaro to study the rear suspension in detail. Not to work on it.
All of the control arms are stamped and formed sheet steel. It seemed to me that any sideways event can bend the arms and throw them out of alignment. If they are out of alignment the 4 CVS joints (2 each side) are abnormally angled. A drive shaft manufacturer told me every 1 degree of angle on a u-joint robs 5 hp out of the drive line. So if you rear drive links are misaligned 2 degrees, that is 2 x 4 joints x 5 HP =40 HP. If it is worse do the math. This is one reason I like a solid rear axle on a muscle car. IRS is finicky. You haveto pay to align all 4 wheels, not just the front 2. I have owned a 1991 Cougar XRZ with HO pushrod 5.0. I know by today's standards that is docile. The point is that vehicle like Camaro5 was same wb, same weight and IRS. Like Camaro5 it had a very nice ride. Ford used a 4 corners hinged plate on that IRS and it stood up to shock and sideways abuse better than stamped steel arms. I would guess your problem is a number of things, one of them for sure is rear wheel alignment. If you going to drive like the Dukes of Hazard or Smokey and The Bandit, get a solid rear axle. That whippy IRS under the Camaro will not take police chase abuse. |
07-06-2013, 09:27 AM | #13 |
Would your observation apply to the front suspension as well? I have no damage to the rear!
And just to clarify,I have done all of the obvious i.e rotation,balancing alignement etc etc Nothing has worked so far. |
07-06-2013, 02:46 PM | #14 |
the alignment could be off....many times I have seen alignemts appereantly ok gone wrong. Recheck it, if that does not work I would try to see bent if u have bent joints of the front subframe, also how is your steering rack connections, have u checked those too?
