01-11-2017, 01:29 PM | #1 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
Turbo kit question
To those building turbo kits and such. I have a question related to the desire for lower cost kits.
You can't do much about the cost related to research and development and tuning so whatever that ends up being is what it is... But my question is really in regards to what I suspect is quite expensive custom metal work. i haven't seen any kits using rubber hoses with steel braided sheaths similar to brake lines for the "Charge" side and always seem to opt for much more expensive custom bent metal tubing. Similarly, some flexible exhaust piping could be used for the exhaust side. I see this used around catalytic converters all the time so they should be viable for turbo use. Wouldn't that significantly reduce the cost of a kit by not needing to custom fab all the tube bends for each application for a manufacturer? Is there another reason this isn't viable? Not having to custom mendral bend connections to the intercooler and intercooler to throttle body and on the exhaust side those connections should mean far fewer unique parts in a kit on top of the lower cost of parts and related labor in designing them. I assume there's something prohibiting this so chime in if you know. |
01-15-2017, 08:03 AM | #2 |
Drives: 2016 1SS Auto Join Date: Mar 2016
We have a barebones piping kit (main charge pipes from turbo to engine bay, custom y pipe, boost pipe to turbo and brace for turbo)
http://www.camaro6.com/forums/showth...64#post9506464 It is more minded for the diy guy who wants to save money and build his own kit. We have all the major components already made in this setup. Just pick either a t4 or t6 frame turbo. Last edited by Goertz; 01-15-2017 at 08:52 AM. |
01-25-2017, 11:08 AM | #3 |
Dyno Show Queen LOL
Very cool sounding kit I fly electronic ducted fan turbines.. reminds of then in sound!
https://youtu.be/nfwrOWeDjOw
01-28-2017, 10:04 AM | #4 | |
Drives: 17 SS a8 Join Date: Feb 2010
on the exhaust side you typically need the support of hard pipes so flexible stuff isn't really practical here either. the high cost is really a sum of a large number of parts. it adds up quickly. for example i am doing a low mount twin kit and need an oil return pump. i purchased the best pump i know of at $400. the oil feed lines and return lines and fittings will likely add up to at least $300. i also got a time delay relay to keep the pump of for a minute or so after the car shuts off. that's another $25. all total i bet i end up with $800 in just the oil feed and return stuff. turbos, wgs, bov and flages were $2800. i am at $3600 already without filters, charge piping, exhaust, heat control, maf fitting. then you have to fuel the thing and tune it.
dropped a valve in the 6.2. now running a drop in rods and piston 5.3
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
