dave@hennessey
Old 11-16-2018, 03:57 PM   #1
chargerfan2
chargerfan2's Avatar
Drives: 2014 Camaro SS 1LE 2SS Summit White
Can I replace just the brake pads?
Have my car at the local Chevy dealer and he looked at my brakes and said the pads are really low. He told my wife with the Brembo brakes that the rotors have to be replaced as well. I was hoping to get them turned and just replace the pads.
chargerfan2 is offline   Reply With Quote
Old 11-16-2018, 04:02 PM   #2
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
As long as the rotors are within spec no need...if you have ANY mechanical ability at all I would suggest changing them yourself, it's stupid simple.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 11-16-2018, 04:15 PM   #3
chargerfan2
They quoted my wife some crazy price to replace the brakes and the rotors. I don't want the stock pads anymore though. I'm tired of all the dust and I don't think they're all that great anyway. Was going to try a different brand. I will do them my self as well. I was thinking of these.
https://www.amazon.com/gp/product/B0...UYDVGV5D&psc=1
Old 11-16-2018, 10:09 PM   #4
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
I would keep the factory rotors, get them turned if needed. Pads are really easy to replace, just drive out 2 pins, no need to remove the calibers
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 11-17-2018, 12:09 AM   #5
CHRISCAM
CHRISCAM's Avatar
Drives: 2013 Summit White 2SS/1LE
As long as the existing pads haven't been worn down so much that the rivets are digging into the rotors, then you don't need to replace the rotors.
Pads are an easy change. If you have a level driveway and a jack & stands you're most of the way there.
CHRISCAM is offline   Reply With Quote
Old 11-17-2018, 10:55 AM   #6
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
As long as the rotors are not warped or too thin after turning them you can get by . But after turning the rotors they will be thinner and will not dissipate heat as well and will not last too long in aggressive driving B4 they overheat and warp .Now if you drive nice and easy they will last a bit ,but did you buy a 1LE to drive nice and easy ? Bottom line is , if you want the car to break like it was when new replace the rotors and pads and check rear rotors and pads and see if they are up to snuff . It is all about what your expectations are and what you are willing to pay .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 11-17-2018, 05:44 PM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
The OEM pads are actually quite good from what I've heard. I did a track day this past weekend with them and they did great.
Old 11-17-2018, 06:37 PM   #8
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
good to hear!
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 11-17-2018, 06:46 PM   #9
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/22 Colorado TB/69 Chevelle
You can go with a carbon ceramic pad if you want less dust. They don't always offer the same stopping power though. If your car is a daily driver and not a track car, that's probably a good pad for you.
GearheadSS is offline   Reply With Quote
Old 11-17-2018, 07:45 PM   #10
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
The 1LE is just perfect the way it is, leave well enough alone.
cornerspeed92 is offline   Reply With Quote
Old 11-17-2018, 08:37 PM   #11
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I'd personally wouldnt ever turn the rotors on this car. Just me though.
When I changed my pads, the rotors have a throwaway thickness. Mine were really close to that, so I changed all of them.
It cost me about 1000 dollars to do it myself. I replaced the TTY bolts as well.
CamaroDreams76 is offline   Reply With Quote
Old 11-18-2018, 07:45 AM   #12
LCPLPunk
USA-1
LCPLPunk's Avatar
Dang, for $1000 you are close to the price of doing a CTS-V or Corvette brake swap. :P
Old 11-18-2018, 11:54 AM   #13
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
when you go 6 piston up front does the clearance outward change? my track set has 3/16 to the spoke from the side of the caliper
Old 11-18-2018, 02:02 PM   #14
vinman
The BBOMG fill-in husband
vinman's Avatar
Drives: 2015 2SS/RS 1LE AKA V1LE
I agree with using OEM pads, they are actually very good
UPSTATE C5 MEMBER
vinman is offline   Reply With Quote
