09-18-2020, 03:45 PM | #1 |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
Who has installed the LPE clutch return spring??
I picked up the LPE clutch return spring (LPE said it will work with the Z/28). The installation looks simple enough, but it appears under the dash is a tad different than in their instructions (metal plate you hook into is designed slightly different it appears from the images), but more to the point, I am having a bitch of a time getting the end of the spring into the hole on the frame. I mean, I can probably bend it out more, or force it with a screwdriver (if I can manage to get both arms below the dash while breaking my back lol), but I don't want to break it.
Is there some kind of trick to getting this damn thing into the hole? |
09-18-2020, 05:24 PM | #2 |
Drives: 2014 z28 Join Date: Oct 2018
I’ve been running no spring since the second time I drove it. Love the clutch feel now
09-18-2020, 06:41 PM | #3 |
Drives: Chevrolet Camaro Join Date: Mar 2020
I have one did not see the hole put out on the metal plate and works great
Sent from my motorola edge using Tapatalk
09-18-2020, 06:49 PM | #4 |
Wasnt planning to remove the current spring (which apparently pushes the pedal down instead of pulling it up), just adding the LPE spring. I've stuck the pedal to the floor before, I'm just working around that issue
09-18-2020, 06:52 PM | #5 |
I think the Z/28 models might be a little different. It gets connected to the clutch pedal a bit below the current spring, then attached to the frame under the dash in a little hole thats just below the wiring and just above the ODBII port (thats the same in all the models I think). I can't get the spring into that hole for some reason unless I do some *adjustment* to the spring
09-19-2020, 08:39 AM | #6 | |
09-19-2020, 08:46 AM | #7 | |
Guess I'll just bend it out a tiny bit. |
09-19-2020, 07:08 PM | #8 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
Does this LPE spring add pedal ‘weight’?
09-20-2020, 07:44 AM | #9 |
From what I've heard it adds a bit of resistance. Will follow up with the thread once I get it installed. I guess I'm going to have to do a little bit of bending to the spring. I'm surprised more people haven't chimed in about the install honestly given how a clutch pedal sticking to the floor can be a bit of a nuisance. I just don't want to limp home in 1st gear or have that "oh shit" moment at high rpm while trying to slowly/calmly press the clutch a few times to try to get some pressure back.
09-20-2020, 09:50 AM | #10 |
Not enough to make a difference
09-20-2020, 10:14 AM | #11 |
Give speed a chance
Is this a common problem with our Zs? Does it occur during "heavy" street usage or is this more of a track problem as a byproduct of boiling brake (clutch reservoir) fluid. Almost sounds like it's a band-aid masking a worn or defective component. Enlighten me please, I too have no desire for the dreaded "oh shit" moment near 7000 RPM!
09-20-2020, 12:56 PM | #12 | |
Gen5diy sells a clutch reservoir kit (which I also bought and am adding) to help with this as well. The return spring is a bit of a bandaid, yes, but my understanding is that when it happens, it will pull the clutch back out, which opens a valve back up to get pressure to the clutch once again. |
09-20-2020, 06:16 PM | #13 |
Give speed a chance
I admire your discipline! I'm a fairly low-key individual but once I get behind the wheel of my Z I transform into a character straight out of an Ed Roth illustration. Thanks for the clutch info. Mentioned in a different post there is a unit offered by JDP Motor sports that I may look into. In addition to the remote reservoir they offer a replacement brake reservoir in their kit for a clean installation.
09-20-2020, 10:01 PM | #14 |
