Roto-Fab
Old 04-25-2013, 03:23 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Splitter guard washers w/black center
I get many emails asking for price, we can not post price here so to see go here. http://www.camaro5.com/forums/showthread.php?t=289554
We now ship all non painted washers with one center washer guard painted black.
Skylane765 is offline   Reply With Quote
Old 04-27-2013, 04:39 PM   #2
firecross91
firecross91's Avatar
Drives: ZL1 #1691 Black on black.
Installed today. Very easy to do. His jack adapters work well also. A couple pics of them installed.
When 580HP ain't enough. JRE 75 RWHP No Tune kit: Featuring ATI, RotoFab, and Torco.
firecross91 is offline   Reply With Quote
Old 04-27-2013, 05:07 PM   #3
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
Received and installed today! They look Great! Love the Jack Pads. Install took like ten minutes, very easy, so now she looks like she's ready to chomp down on anything that gets in her way. Thanks, and the Check is in the Mail, as the saying goes. I highly recommend these washers, and the New Jack Pads. Look great and should do the job! Also at a great price!
Normagene is offline   Reply With Quote
Old 04-27-2013, 05:09 PM   #4
firecross91
Did you use the center spacer?
Old 04-27-2013, 05:16 PM   #5
ayousef
ayousef's Avatar
Drives: 2013 ZL1
whats the point of the center one being black? Also how high are the washers it also seems that you are loweing your ground clearance by having the washers so you will hit them more often than not having any washers at all.
Im thinking the washers had to be shorter/thinner?
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 04-27-2013, 05:20 PM   #6
firecross91
If you vehicle is going to rub the short length of the spacers won't cause a problem. I should have taken a pic of the underside of the splitter. I was amazed at the wear damage already done after only 2500 miles. I think he is using a black spacer in the middle to blend in. I got all black and didn't install the center one. I have a high approach driveway and just about always scrape backing out.
Old 04-27-2013, 07:00 PM   #7
Skylane765
Skylane765's Avatar
The reason I make the center black is because it will be in view easier because it is placed close to the front.
We do not have to make the center black, I was doing that for the customers do not need to have them all black.
maybe I should come out with a pole and see if that is what you all would like.
The washers only add 1/8 extra to the bottom. the OEM screws stick down 1/8 inch. When you use the Splitter Washers they come with screws and the total is 1/4. so the net ground clearance is only 1/8 inch more. That is nothing if you compare what it will do if you scrape the OEM screws off. The splitter washers are only .25 or 1/4in in depth, the screws you remove are over 1/8in in depth.
Old 04-27-2013, 09:47 PM   #8
Normagene
Normagene's Avatar
Not yet, I didn't jack up the car, I just laid on the ground and had more than enough space to do the job. But to install the center washer you have to drill a new hole. There is no OEM screw in the center. So to fit my drill underneath I'd have to jack it up or use my flex drill extension. I can do that at a letter date, I only had 30/40 minutes and also installed my rock/splash guards. Best deal I've seen yet, One-Bad-ZL1, makes a set and they really look good. I'll post a pic tomorrow.
Old 04-28-2013, 01:20 PM   #9
Normagene
Normagene's Avatar
Here's my pic, not that it's any different than anyone else's. Now do I have to bring in a hygienist to keep those teeth clean? Hey, maybe skylane can come out with a set with a fixed screw and a hex nut bottom to tighten and a pointed tooth instead of flat. Haven't had a chance to put in the center black one.
Attachment 503773
Also put on my rock/splash guards from One-Bad-ZL1
Old 04-28-2013, 01:21 PM   #10
Normagene
Normagene's Avatar
Pic didn't post for some reason. Second try.
