Old 06-23-2009, 12:19 AM   #1
novajess1972
I Done Caught Diabeetus.
novajess1972's Avatar
Drives: 1972 Chevelle SS/2010 Tundra
Running foglights and halos simultaneously?
Judging from the pics I've seen, is it safe to assume that you can't run the fogs and headlights simultaneously?
Anyone disappointed?
CANCELLED ORDER: 1SS/CGM/MN6/BLACK RALLY STRIPES
novajess1972 is offline   Reply With Quote
Old 06-23-2009, 12:25 AM   #2
Rocky918
Rocky918's Avatar
Drives: SS for Super Sexy!
i am VERY disapointed in this ... because i would like that option .. however, running the halos at night does give the car quite a mean look as it has like glowing cat eyes kinda .... but i still want the option to run both at the same time
- Life is to short to let it pass you by
Rocky918 is offline   Reply With Quote
Old 06-23-2009, 12:34 AM   #3
wullger
Supercharged
wullger's Avatar
Drives: 2010 Camaro 2SS/RS
:bangdesk::bangdesk:
wullger is offline   Reply With Quote
Old 06-23-2009, 12:35 AM   #4
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
yes, this is why I did not order the RS with the SS since I can't justify paying that much for headlights..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 06-23-2009, 01:04 AM   #5
bluch
OH CANADA!
bluch's Avatar
Drives: 2011 RAM 1500 LARAMIE
WHAT?! YOU CANT RUN THEM BOTH AT THE SAME TIME! WELL THEN, I AM JUST GOING TO HAVE TO CANCEL MY ORDER!!!!!! :bangdesk::bangdesk:
bluch is offline   Reply With Quote
Old 06-23-2009, 01:47 AM   #6
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
HHHHmmmm! I am wondering now when I add the Halo's to my SS.... wire it to the Fog light switch..... cool!
2SSJIM is offline   Reply With Quote
Old 06-23-2009, 01:59 AM   #7
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
or just put the fogs on there own independent switch that way it doesn't interfere with the DRL
Gentry78 is offline   Reply With Quote
Old 06-23-2009, 02:03 AM   #8
Shaggy
2010 Maro owner
Shaggy's Avatar
Drives: 2006 Chevy Truck
Give it time, there will be a aftermarket deal you can buy that will allow this.
Shaggy is offline   Reply With Quote
Old 06-23-2009, 02:15 AM   #9
Gentry78
HOOK'EM
Gentry78's Avatar
booo
just kidding all you need is a switch from your local autozone/oriley's or hell i think walmart has them and couple feet of wire with splice connectors. then just look at the headlight switch figure out which is ground, and power for the fogs(DRL) splice in and your done after you mount the switch and of coarse tuck everything back to make a nice clean install
Old 06-23-2009, 07:56 AM   #10
greenrail
Comic Curmudgeon
greenrail's Avatar
Drives: 2010 Camaro 2SS-2010 VW CC Sport
This has been posted on here about a dozen times sincethe car hit the streets. It is clearly stated inthe owners manual that the "Foglights" are DRL's not Foglights. THe HID's will give you plenty of light at night.
I am sure you and many others will rewire your DRL's on a separate circuit so you can switch them on and off as you wish.
Member Illinois Camaro Club
His Name is Rosie - "Speak Softly and Carry a Big Stick!" - If you know who said that, then you know the genesis of his name.
greenrail is offline   Reply With Quote
Old 06-23-2009, 08:02 AM   #11
Georgie
Georgie's Avatar
Drives: Camaro... soon
so halos cannot be run with the fogs.... can the regular halogen headlights be run at the same time as the fogs?
2011 IOM or CGM 1SS
Georgie is offline   Reply With Quote
Old 06-23-2009, 08:06 AM   #12
Supermans
Supermans's Avatar
Yes, regular headlights and fogs work together during foggy situations to help you see better. Halo's and fogs are two different colors and would look silly both on at the same time..
Old 06-23-2009, 08:12 AM   #13
Georgie
Georgie's Avatar
another con for the RS, at least for me. thanks Supermans
2011 IOM or CGM 1SS
Old 06-23-2009, 08:56 AM   #14
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Why would you want to run the "fog lights" the same time as the HID's? The HID's give out far more light then the halogen lights in the "fog lights" so the "fog lights" will not improve your visibility at all. It would be like pointing both a key chain flashlight and commerical grade spotlight in the same direction and thinking that the key chain helps you see.
If you wanted to do it for looks, the factory "fog lights" would look silly with the HID's so you would have to change them to HID as well. This would be extremely blinding to other drivers and in some areas if your headlights blind a driver and it causes an accident, YOU are listed as being at fault.
