Old 02-08-2015, 12:28 PM   #1
SilverSlayer-SS
SoCal HT5
SilverSlayer-SS's Avatar
Drives: 2010 SS , 2014 SS
2016 Camaro headlights appear on ebay!
Updated 2/14/15:
Comments and photo posted by CFTA showing closeup of the 2016 Camaro headlight projector bulb, which shows that there is no LED halo ring.
Originally Posted by CFTA
The bulb for the projector, seems to be HID and missing, appears to be powered by a secondary ballast which was not present in any of the housing shown on ebay. I will still try to see if the newer HID D3 bulbs are a direct fit or if its a new/different type of bulb socket. The 14-15 RS cars use D3 bulbs with 55w ballasts while the 2010-2013 use 35w D1s. Wires for any possible hid ballast, as well as the highbeam cutoff shield had been cut. The cutoff shield motor is intact and from what I recall, it is a 3 wire set up.
The main plug for the headlight is an 8 pin setup. The LED DRL ballast was first removed and all wiring traced throughout the headlight. It is made by AL in germany and the same style used in Audis. Two pins in the one corner of the main plug run directly to the LED DRL ballast, 4 or 5 wires run from that to the LED circuit boards(3 of those). There is no other connection from the LED ballast going to anything else. Ground pin was found just by checking continuity of the pins and seeing which had no resistance to the metal housing of the ballast. It was powered up right after figuring that out. The LED strip is bright and glows almost like fiber optics, no single point LEDs are visible. The LEDs sit about 4 inches back from the front edge.
The turn/marker light is lit in the same manner that the current 5th gens are, a bulb in a standard socket goes into the back and rotates to lock it in. The socket lock pattern however is not the same as 14-15 cars.
Getting back to the main headlight, no halo as I previously said, at least not in these versions. I have yet to confirm what country the cutoff shield is for. I'm pretty sure it looked to be for a LHD setup. So US, canada, Europe(excluding england), etc. One cut wire coming into the headlight leads to a wire coiled around a ring, the type of thing sometimes used on the 12v power lead to an HID ballast. It possible that the ballast is part of the rear cover to the headlights.
All this was done/observed in a matter of maybe 10-15 min with the headlight so that is why I can't be sure about some details right now. I will find out more though.
Original post 2/8/15:
http://www.ebay.com/itm/CHEVY-CAMARO...6fc27b&vxp=mtr
There is a guy with 3 of them posted on Ebay. The guy is from Ypsilanti, Michigan.
The product label matches the 6th gen Camaro program code - A1BC.
Originally Posted by FenwickHockey65
A= Alpha
1= 1st generation Alpha platform
B = Coupe
C = Chevrolet
Photos:
Originally Posted by Mr Twisty
SilverSlayer-SS is offline   Reply With Quote
Old 02-08-2015, 12:30 PM   #2
Bizaro
Drives: 2015 Redhot 1LE
2014+ RS package have different lights yes, but the ebay posting you are referring to is not OEM its after market.
Bizaro is offline   Reply With Quote
Old 02-08-2015, 12:33 PM   #3
SilverSlayer-SS
SoCal HT5
i am aware of that since i have both the 2010 and the 2014 models , but the listing says that its an OEM piece , so i thought i would share it to get some information , the light looks like it doesn't fit a camaro , I've taken out my headlight on my 14 rs to install the oracle kit , and i can tell it doesn't look the same perhaps different edges
Old 02-08-2015, 01:01 PM   #4
xRedsox
Night Fury
xRedsox's Avatar
Drives: 2016 Golf R
The headlight has damage anyway so I wouldn't even bother with it.
2014 2LT RS A6
Mods: K&N Intake, Magnaflow Axleback, BMR Strut Tower Brace, VTC Throttle Controller, Tune.
xRedsox is offline   Reply With Quote
Old 02-08-2015, 02:26 PM   #5
Trip
Trip's Avatar
Drives: 2015 White RS 2SS 1LE
My guess would be the auction is titled wrong and that's not a Camaro headlight.
Trip is offline   Reply With Quote
Old 02-08-2015, 03:06 PM   #6
camaro2lt
camaro2lt's Avatar
Drives: 2010 Camaro 2LT VR/RS CGM Rally's
I wouldn't bother with it
camaro2lt is offline   Reply With Quote
Old 02-08-2015, 03:16 PM   #7
SilverSlayer-SS
SoCal HT5
but there is "camaro" engraved on the light lens, im not interested in buying this particular light, I just posted it to know if there is an oem light thats different than the ones we have or if its an aftermarket part
Old 02-08-2015, 03:35 PM   #8
djoker08
HTCC Member
djoker08's Avatar
Drives: 2018 ZL1 1LE HBM
They look custom made and look similar to the headlights on bumblebee from transformers 3
djoker08 is offline   Reply With Quote
Old 02-08-2015, 07:54 PM   #9
Trip
Trip's Avatar
I didn't notice CAMARO written on there, now you've got me curious to how they look on the car.
Old 02-08-2015, 08:15 PM   #10
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
They say ECE on them. My guess is Euro Spec
2011 2SS/RS built 8/24/10
Old 02-08-2015, 08:21 PM   #11
oldfriend
Drives: Fiat 500 E
I just keep on amazing myself on what some people can say to make a sale
In another words , some will say just about anything just to try to sale something !
oldfriend is offline   Reply With Quote
Old 02-08-2015, 08:22 PM   #12
camaro2lt
camaro2lt's Avatar
I would agree and say they are for europe
Old 02-08-2015, 09:49 PM   #13
fradaj
Drives: RS
I have never seen a headlight like that either, that LED strip is kind of cool.
fradaj is offline   Reply With Quote
Old 02-09-2015, 02:59 AM   #14
fradaj
Drives: RS
C6 Headlights
There was a post on the C5 forum about 2015 headlights. There is a guy with 3 of them posted on Ebay. The guy is from Ypsilanti, Michigan. The only thing is I don't think they are for a C5, they look like they may be for the C6. They have been damaged. I'm thinking they may have ended up in the trash at GM or something and this guy got ahold of them somehow.
2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 camaro spy, 2016 camaro spy photo, 2016 camaro spy photos, 2016 camaro spy pics, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
