AWE Tuning
Old 01-19-2024, 04:54 PM   #1
Mero210
Drives: 2018 2SS 1LE Black
1LE Front Splitter DISCONTINUED???
Hi All,
Sorry if I suck at researching existing threads, but I just got into a bit of a fender bender (or perhaps I should say splitter breaker) with my 2018 2SS 1LE.
Filed a claim with my insurance since it was a hit and run and I had damage to a wheel, etc. Long story short, shop cannot find the splitter (GM 84116157 or GM 84116158) and they are coming back with it being discontinued
I am at the point where the car is going to be returned to me with a credit and no splitter.... Does anyone have any leads on a OEM splitter source or what GM could have designated as the new PN? I read somewhere that GM makes spare parts for 7 years. I don't understand how there are no OEM replacement parts anywhere....
Can the GM 84116168 be used??
Many thanks in advance!
Mero210 is offline   Reply With Quote
Old 01-19-2024, 05:06 PM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Not sure but if you can't find it get one used on ebay, plenty of crashed cars out there getting parted out.
Christian1LE is offline   Reply With Quote
Old 01-19-2024, 06:29 PM   #3
22SS1LE
Drives: 2022 1SS 1LE 6M
https://www.c6performance.net/catalo...-p-533365.html
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22
New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17
8/24. IT HAS ARRIVED at the dealer
8/25- It is in the Garage
ACS ZL1 Sideskirts, 20% tint, CAI Intake
22SS1LE is offline   Reply With Quote
Old 01-21-2024, 05:21 PM   #4
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I used the 2nd gen splitter from ACS when I replaced mine https://acscomposite.com/products/1le-splitter-20
carguy55 is offline   Reply With Quote
Old 01-22-2024, 10:58 AM   #5
beworthy3
beworthy3's Avatar
Drives: 2018 Camaro SS 1LE
I went ACS when I broke my splitter at autox. Not the cheapest but they are very durable and will not break as easy as OEM
beworthy3 is offline   Reply With Quote
Old 01-22-2024, 12:10 PM   #6
cdrptrks
cdrptrks's Avatar
Drives: 2017 Blue Camaro 1SS 1LE with PDR
You wouldn't want to replace the original OEM splitter with another one even if it was available. It is badly designed with thin plastic that cracks easily.
https://www.camaro6.com/forums/showthread.php?t=516368
I have the newer style Ikon splitter that's a reproduction of OEM just without the flat bottom, and in 3 pieces (like on the C8 Corvette) presumably to reduce shipping cost. I consider them consumables on this car so idk if it is worth paying extra for an expensive brand like ACS when both brands are made of ABS plastic.
https://www.ebay.com/itm/284648502349
The Ikon has held up ok for me after lots of track days with just some slightly visible scraping (if you're within a few feet) on parts of the bottom front edge which actually might have been caused by street driving rather than track driving. It mounts with just the stock bolts and provided self tapping phillips head screws which is much faster/easier than the 3M adhesive strip used on the original splitter that came on my car. The Ikon splitter has stayed in place at almost 150mph on track. I did remove the one remaining small bottom plastic edge cap piece after the other one fell off while driving on the street shortly after I installed the splitter. It looks the same with and without those pieces.
cdrptrks is offline   Reply With Quote
Old 01-22-2024, 12:38 PM   #7
cdrptrks
cdrptrks's Avatar
If you prefer the original look, this one looks like a reproduction but I don't have personal experience with it: https://www.americanmuscle.com/camar...5_Var4=CC11058
I did have the Ikon original look reproduction splitter (no longer made/sold) on my car for several years and it looked identical to the original one but the plastic was thicker.
Old 01-22-2024, 01:07 PM   #8
cdrptrks
cdrptrks's Avatar
These also look like they might be reproductions of the original splitter or at least a similar design:
https://www.amazon.com/dp/B09LQCZ11F
https://www.amazon.com/dp/B08ZHZX8QR
Old 01-22-2024, 02:40 PM   #9
Mero210
Thanks, i have tried with no luck. I found one on Offer Up but sold before I coudl get it. It was NIB for $150 satin black :0
Old 01-23-2024, 08:43 AM   #10
Mero210
Thanks cdrptrks (and everyone else), that American muscle one looks very promising. I actually went through my insurance this time because I jacked my wheel and needed an alignment, etc. Their parts department keeps asking ME for sources since they cant find it. I had initially sent them a couple of the ones in this thread (all OEM) but they got their orders cancelled due to no inventory. You all are right though, I was trying too hard to keep the OEM look, but venturing out to a cheaper aftermarket one may be the right approach here. I had broken and repaired before twice, the OEMs ARE crap in terms of quality and durability
Old 03-02-2024, 10:28 AM   #11
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Ugh, should have bought one a couple years back.
'18 1SS 1LE Black, PDR
Old 03-03-2024, 04:24 PM   #12
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Will the newer style (19+) work on the 17-18 models?
Sent from my iPhone using Tapatalk Pro
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 03-03-2024, 09:18 PM   #13
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Perhaps available in different color - that can be repainted ?
Black = 84116099
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 03-04-2024, 08:27 AM   #14
Cardiak
Drives: Boat
Yikes. Someone just bought a 2018 that I was watching. The splitter was damaged pretty good.
Cardiak is offline   Reply With Quote
1le, 1le 2ss, 84116157, splitter
