dave@hennessey
Old 10-20-2014, 12:53 PM   #1
kartracer
Drives: 2015 Black Z28
E85 Fuel
I'm wondering if the Z28 is designed to run on it, and if so does it increase the HP?
Thanks,
kartracer is offline   Reply With Quote
Old 10-20-2014, 04:37 PM   #2
zbzo6
Drives: chevy corvette
If it could it would say so in the manual.
zbzo6 is offline   Reply With Quote
Old 10-21-2014, 07:35 PM   #3
DickytheStump
Drives: '15 z/28, '12 Boss 302, '13 427 con
Thanks,
I would not even consider it.
DickytheStump is offline   Reply With Quote
Old 10-23-2014, 04:58 PM   #4
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
Alcohol requires MUCH more fuel to produce power. A buddy once ran a pure alky car on the street. He got about 3 miles per gallon...but it was a 13:1 compression 468 C.I. street monster .
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 10-23-2014, 05:42 PM   #5
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
+1000, E85 is a waste of food and you will get less MPG and most likely less HP! FYI, the higher the Octane the less alcohol that you have!
Old 10-23-2014, 05:46 PM   #6
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
great post keep spreading false info on E85
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 10-23-2014, 05:49 PM   #7
Ryanbabz71
Ryanbabz71's Avatar
Go look at the 2014 silverado and the HP gains it has on E85 per GM. It adds an additional 20. Not saying this is typical for other vehicles just an example
Ryan
Ryan
Old 10-23-2014, 05:55 PM   #8
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
On my 09 Suburban I tried E85 maybe 10 times and each time the fuel mileage was so far down it was never worth the cost savings.
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
Old 10-23-2014, 05:57 PM   #9
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 10-23-2014, 05:59 PM   #10
Bhobbs
Bhobbs's Avatar
Alcohol produces less energy when it is burned so you have to burn more to get the same power as gasoline. Alcohol has a higher resistance to detonation so you can run higher compression and make more power.
Old 10-23-2014, 06:15 PM   #11
1badtie
1badtie's Avatar
Drives: 2018 Camaro ZL1
just got a new work truck (2015 silverado HD with 6.0) and it says E85 on the gas cap.
filled up once with E85 and it got terrible MPG, have not put it in since
2018 ZL1 M6 NGM
PPF and Ceramic coating
IG: NGMZL1
2010 2SS RS --- SOLD
MODS-
Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb
Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs
1badtie is offline   Reply With Quote
Old 10-25-2014, 10:47 AM   #12
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
no...
2013 ZL1 #7860 is offline   Reply With Quote
Old 10-25-2014, 11:23 AM   #13
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
It has to get tuned for it, then yes the HP will increase.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 10-25-2014, 05:47 PM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Its not just the tuning. Ethanol doesn't always play nicely with the rubbers & plastics found in most fuel systems. Tends to be corrosive. Cars that are E85 capable are built to accept ethanol in high concentrations. Most production cars are not, their limit tends to be about E20 or E25 before it starts to affect them.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
