Old 09-28-2018, 08:51 AM   #1
ChevyTaco
Drives: 2018 Camaro SS
Trunk won’t open with use of electronic releases
Hello,
I have a 2018 Camaro 1SS Coupe. This morning I went to open my trunk by using my key fob and the trunk wouldn’t open. Tried using the other two methods (door button and license plate button) and it still wouldn’t open. I tried going into the trunk from the inside and using the emergency manual release but couldn’t find the pull chord in my trunk. Does anybody know what I should do?
Bone stock
ChevyTaco is offline   Reply With Quote
Old 09-28-2018, 10:21 AM   #2
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Will the car start... sounds like the battery is dead.
I would go back inside the trunk with a good flashlight and find the pull handle
Old 09-28-2018, 10:53 AM   #3
ChevyTaco
I forgot some information in my first post. The battery is fine. When I use an electronic release I can hear a click, like the latch wants to open but can’t release all the way. I looked inside the trunk with a flash light. Can’t find the emergency latch. I think I’m gonna have to take the car into the dealership this weekend :(
Bone stock
Old 09-28-2018, 10:55 AM   #4
VinnAY
Drives: 18 1SS/1LE
Is the parking break set?
VinnAY is offline   Reply With Quote
Old 09-28-2018, 11:05 AM   #5
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Also is it in Valet Mode?
thescreensavers is offline   Reply With Quote
Old 09-28-2018, 11:07 AM   #6
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Crawl all the way inside the trunk on your back. You will be staring right at the release.
Old 09-28-2018, 12:27 PM   #7
Deltronicx18
Drives: 2017 camaro 2ss,A8,MOSAIC BLACK MET
I HAD THIS SAME PROBLEM. How I got the trunk open.1 push the trunk down hard. make sure it locked.2 lift up bottom edge of the trunk then keep pushing the trunk open button .3 while lifting the trunk up press the open button under the trunk. Keep doing this the trunk will open.
Deltronicx18 is offline   Reply With Quote
Old 09-28-2018, 12:34 PM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
^^^This... I've heard of others doing this as well.
Old 09-29-2018, 04:59 AM   #9
VinnAY
Drives: 18 1SS/1LE
UGH....i had enough trunk locking problems with my Mustang, this rears its head on my car I'm gonna be pissed
Old 09-29-2018, 09:18 PM   #10
trz174
trz174's Avatar
Drives: Used to Drive Blue Camaros
Oddly enough, I just had the same problem. None of the solutions above worked for me. While in the trunk (on my back, in the dark with a flashlight), I noticed a hole next to the latch. The hole is the access for another manual release option. It looks like a 3/8 hex square would work, but it’s not a 3/8 square. So, I used a medium sized screwdriver that fit across the square and turned it. The trunk popped right open.
trz174 is offline   Reply With Quote
Old 09-29-2018, 09:32 PM   #11
Chazzz
Chazzz's Avatar
Drives: 2018 1LT RS V6 A8 Convertible
More than likely it is the black round stoppers in the trunk are out of adjustment. This is a common issue, simply push down on the trunk while pushing the trunk open button and when it opens adjust the round stoppers until it opens properly.
Chazzz is offline   Reply With Quote
Old 09-30-2018, 02:32 AM   #12
Deltronicx18
Loosen the rubber stopper. About one turn around and it should work from there.if doesn't work it could be the electronic trunk popper broken!
Old 09-30-2018, 09:41 AM   #13
retmil
Drives: 2022 Wild Cherry SS
I have had the same issue on my '17 coupe a couple of times and it was the latch being out of adjustment just enough for it not to release the trunk. I moved it - with my hand - either right or left and fixed the issue.
retmil is offline   Reply With Quote
Old 06-27-2019, 05:56 AM   #14
Mich2112
Mich2112's Avatar
Drives: 2018 1SS 1LE
My 18 is doing this too. 90% of the time it works fine, but when I’m in a hurry it pulls this mess. Too many people are having the same issue so I would say it’s a design flaw.
Mich2112 is offline   Reply With Quote
