Old 09-05-2010, 09:11 AM   #1
nalinc23
nalinc23's Avatar
Drives: 2010 2SS/RS 6MT
Tire Pressure Questions
Good Morning:
I have the OEM 20's and had a couple questions about the tire pressure/TPMS.
1. When I got the car the tire pressure was showing uniformly in the range of 32-35 psi but I wanted to know what the recommended tire pressure was from everyone and what it was from the manufacturer?
2. It seems like I will add air to the tires to the tune of 35 or so PSI and not too much time will pass and I'll get a warning that the tires are down to 31 or 32 and this is pretty uniform (not a trouble tire for example). Anyone else see the air drop kind of quickly?
'10 2SS/RS 6MT, Silver Ice Metallic/Black, CAI Inc Intake, Magnaflow 3'' Catback Exhaust 16483, Llumar 35% Tint, Headlight Armor 20% for Fog/Side/Tail Light Lenses
nalinc23 is offline   Reply With Quote
Old 09-05-2010, 09:22 AM   #2
hansenp
hansenp's Avatar
Drives: 2010 Camaro 2 SS/RS
Its says in the drivers door 36 psi cold. I set mine at approx 38 cold. 32 is too low
hansenp is offline   Reply With Quote
Old 09-05-2010, 09:35 AM   #3
grip750
grip750's Avatar
Drives: 2SS Victory Red
I set mine to about 40, in a couple of weeks it is at 36-37. Just easier for me to not have to add air every month.
grip750 is offline   Reply With Quote
Old 09-05-2010, 11:17 AM   #4
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
My TPMS seems to under report. My gauge says 38-40 but the sensors report 35 -37 I don't which is wrong. I need to try another gauge I guess.
gr8daneh is offline   Reply With Quote
Old 09-05-2010, 11:37 AM   #5
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: None
Trust the gauge over the TPMS, or you'll be putting air in every week.
Baldman is offline   Reply With Quote
Old 09-05-2010, 11:44 AM   #6
maxpower5
maxpower5's Avatar
Drives: 2010 Shelby GT500
very true here. depending on temp change outside, expect to have to let air out when its warmer and add air when its cooler. my tire pressure stays pretty constant - i check it about 2x's a month. 36 psi is recommended, lower than that, decreased gas mileage, above that, may tire may wear unevenly.
maxpower5 is offline   Reply With Quote
Old 09-07-2010, 08:40 PM   #7
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
mine has dropped lately on the right side for whatever reason, got the compresser out and inflated them all to 37 going with the DIC reading. they were reading 32 or lower. the 18's I run have a max 44 psi so I go with something right in the middle between 32 and 44
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
Old 09-07-2010, 10:16 PM   #8
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
Just a recommendation, but tire pressures should be checked at least once a week manually, and adjusted thereafter. Just a few psi off can increase load, fuel mileage, tire wear/longevity, and of course handling. Sometimes people (not you btw, just happened to quote your post!) forget that tires are the last thing that keeps your car on the road and are an important part of the suspension.
When taking your drivers license in Europe you are taught to check your tire pressure every time you fill up for gas, and they practice that routine quite well! Its a cheap insurance to spend 5 min a week checking pressures, instead of getting a flat tire and having an accident.
32 cold is way to low, as 40 is way to high! Tire pressures usually increase about 2-4 psi when hot, even more when driving hard. That barely gets the 32 up to the proper cold pressure, and almost to 44psi when starting at 40.
I drive an average of about 45k miles/year and have done so for the past 8 years and to this date never had a single flat tire. Although just because I wrote that I'll probably wake up to 2 flat tires tomorrow morning but you get the point
Erik@Torq is offline   Reply With Quote
Old 09-10-2010, 08:08 PM   #9
cmcghee559
cmcghee559's Avatar
Drives: 2010 Camaro LT2
My sensors have started to read low, about 3 to 4 lbs below what my guage says...I have two guages and use them both...got any ideas as to why I cannot get them read with the guages>>||?????
Which Cowboy T shirt to wear today?
cmcghee559 is offline   Reply With Quote
Old 09-10-2010, 11:05 PM   #10
l008com
l008com's Avatar
Drives: 2013 1LT Crystal Red/Beige Manual
I set mine to 38 psi cold. I just got my first oil change at a chevy dealer, and today I got an email from onstar telling me that all my tires are low. Apparently they lowered all 4 tires to a cold pressure of 32 psi. To tomorrow I get to go spend a half an hour with my bike pump putting them back to 38. Fun stuff.
l008com is offline   Reply With Quote
Old 09-10-2010, 11:14 PM   #11
oldfriend
Drives: Fiat 500 E
2SS
Originally Posted by nalinc23 View Post
Good Morning:
LOOK AT THE DRIVER DOOR , the manufacturer did some testes and has the best in mind when they tell you what to do!!!!
oldfriend is offline   Reply With Quote
Old 09-10-2010, 11:14 PM   #12
l008com
l008com's Avatar
I wish the service guys would do that.
Old 09-11-2010, 03:31 PM   #13
i007spectre
i007spectre's Avatar
Drives: 2016 2SS, 2008 HHR ECTO-2H
Yeah with my first oil change they were supposed to check the tires for me. I left with 32psi in all four. I have 35psi in them now.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25
2000 - 9/28
3000 - 9/30
3100 - 10/27
3300 - 10/28
3400 - 10/29 TPW 11/09
3800 - 11/10
4300 - 11/24
4B00 - 11/25
4200 - 12/5
5000 - 12/7
6000 - 12/11
i007spectre is offline   Reply With Quote
Old 09-11-2010, 03:32 PM   #14
i007spectre
Oh and my gas mileage is better now as well.
1100 - 9/25
2000 - 9/28
3000 - 9/30
3100 - 10/27
3300 - 10/28
3800 - 11/10
4300 - 11/24
4B00 - 11/25
4200 - 12/5
5000 - 12/7
6000 - 12/11
Tire Pressure Monitoring Trouble recontango Wheels and Tires Talk Sponsored by The Tire Rack 16 12-04-2011 08:15 AM
Tire / Rim questions Arsenal11 Wheels and Tires Talk Sponsored by The Tire Rack 11 05-14-2010 08:02 AM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 08:04 PM
Bridgestone RE11 Performance Tire Review Info@PeddersUSA.com Suspension / Brakes / Chassis 4 12-28-2009 10:58 PM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 03:34 PM
