12-18-2017, 03:09 PM | #1 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Jack spacer
Due to some particular problems with my condo, I can’t use my ramps to drive on, however I can drive off. But my jack that I have (Harbor freight 1.5) won’t go high enough to seat them properly on the ramp as if I drove on.
So none of that that is really important, LOL..... the question is: has anybody found a spacer to use on their Jack? Or made a safe one? I need about a 4 inch spacer, in addition to my frame Puck. |
12-18-2017, 03:28 PM | #2 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Something like this.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
12-18-2017, 03:29 PM | #3 |
A bit Bigger...
12-18-2017, 03:34 PM | #4 |
Bigger in terms of longer? I do those on request . They have a magnet as well.
Soleil
12-18-2017, 03:39 PM | #5 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
Buy a 2x4. Cut as many spacers as you need.
12-18-2017, 03:44 PM | #6 |
Nice...need 4 inches I think
12-18-2017, 03:45 PM | #7 |
Not that again, had two 2 x 4’s split on me on my C7 doing this… Need something stronger .....
12-18-2017, 03:46 PM | #8 |
Drives: 2016 2SS Convertible Join Date: May 2012
I see what you mean. You have to lift the frame a long way to pull the tires high enough to put a ramp under them. Can you lift the car high enough to slide the ramps partially under the wheels and then drive the rest of the way up on to the ramps?
12-18-2017, 03:50 PM | #9 |
Drives: 2017 2lt rs Join Date: May 2017
Piece of steel pipe ,thick wall or round stok material ? Be careful of tipping
12-18-2017, 03:51 PM | #10 |
Not really, but thanks for your message, the condo Floor we are on is extremely slippery and it pushes ramps ahead and there’s no way to anchor them to the floor… Coming off is no problem they don’t scoot out , but going up is ifffy.....And I need the height of my ramps, to really get under the car , as I stopped being skinny along time ago......
12-18-2017, 03:56 PM | #11 |
My Rhino Ramps have a rubber foot that helps keep them from sliding. As soon as I get the weight of the car on the front of the ramp it seems to plant them pretty well.
Would there be a way to make a rubber foot for your ramps to help keep them from sliding? Or maybe a way to safely put a piece of lumber between the tall end of the ramps and a curb or other solid object to prevent them from sliding? |
12-18-2017, 03:57 PM | #12 |
Yup, gonna go cruise Lowe’s for this, cut two notches for frame
12-18-2017, 03:59 PM | #13 |
Excellent idea......
12-18-2017, 04:17 PM | #14 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
I use a lift puck from Amazon and then an additional hockey puck. The height is perfect.
